Transponder antenna
mike(at)vision499.com
PostPosted: Sat Nov 11, 2017 4:15 pm    Post subject: Transponder antenna Reply with quote
In a composite aircraft does the transponder antenna have to be outside the fuselage?
If it can be inside how do you make a ground plane?
Is it OK to be close to the COM antenna
Mike
rlborger(at)mac.com
PostPosted: Sat Nov 11, 2017 5:17 pm    Post subject: Transponder antenna Reply with quote
Mike,
FWIW, I used the Archer transponder antenna for composite aircraft. It is a full wave antenna that doesn’t require a ground plane. Works great.
Having a warm body close to a comm antenna will distort the transmission pattern. But it would be difficult to say how much. Better if it were some distance away. I have my comm antenna in the tail.
Blue skies & tail winds,
Bob Borger
On Nov 11, 2017, at 18:13, mike(at)vision499.com (mike(at)vision499.com) wrote:
<![endif]--> <![endif]-->
Mike
Airdog77
PostPosted: Sun Nov 12, 2017 2:00 am    Post subject: Re: Transponder antenna Reply with quote
Mike,
No, none of the antennas have to be outside the aircraft.
Check out the Advanced Aircraft Electronics L2 Transponder Antenna made specifically for composite aircraft, no ground plane required and costs less than $100.
http://www.aircraftspruce.com/catalog/avpages/antennasystems1.php?clickkey=4083
Is it OK to be close to the COM antenna?
If you mean the transponder antenna, from my understanding no. I think you want to be as far away as possible, within reason. Different antennas may have different requirements.
Wade
Airdog
Wade Parton
Building Long-EZ N916WP
www.longezpush.com
donjohnston
PostPosted: Sun Nov 12, 2017 5:02 pm    Post subject: Re: Transponder antenna Reply with quote
If your composite is fiberglass, it does not have to be on the outside. If it's carbon fiber, then you may have some issues.
I used aluminum. Here's how I built mine.
http://www.velocity-xl.com/blog/2013/11/07/13-99-transponder-antenna-ground-plane/
In a perfect world, they would be as far apart as possible. I'm sure there's a recommended minimum. But I don't know what that is.
ceengland7(at)gmail.com
PostPosted: Sun Nov 12, 2017 5:32 pm    Post subject: Transponder antenna Reply with quote
That design is great for those of us who are financially challenged; you
can buy the little spike antenna for around $20. Add a bit of scrap
aluminum & you're done.
donjohnston
PostPosted: Sun Nov 12, 2017 6:50 pm    Post subject: Re: Transponder antenna Reply with quote
Not sure about the "financially challenged" comment. I didn't see the benefit to spending $100's on something that I could build for about $25.
If that makes me "Financially challenged" then so be it.
PostPosted: Sun Nov 12, 2017 7:15 pm    Post subject: Transponder antenna Reply with quote
An earlier post mentioned a dipole for ~$100.00. The $20+aluminum scrap
is the alternative for us 'financially challenged'. When I wrote 'That
design', I was referring to the spike.
Airdog77
PostPosted: Sun Nov 12, 2017 7:15 pm    Post subject: Re: Transponder antenna Reply with quote
Good point. I should have noted the carbon fiber caveat.
I went the same way you did initially Don, and it is fairly easy and cost effective. But then after I ran across a few builders who used the L2, it solved my issue of finding a location for mounting the antenna, and also kept from having anything poking out (for us non-CF folks!).
Wade
Airdog
Wade Parton
www.longezpush.com
steve(at)tomasara.com
PostPosted: Mon Nov 13, 2017 6:45 am    Post subject: Transponder antenna Reply with quote
A word of caution related to putting your transponder antenna inside your cabin...
*IF* you are or will be using an ADS-B out 1090 MHz transponder on the antenna in question be aware that it's output is enough different than the non-ADS-B transponder that where the later would work with no problem, the former may inject "ticks" into your audio.
My antenna is an exterior antenna just under my legs with a minimum (1/4 wave radius) circular ground plane (it's been tested and provides and excellent match) and when I switched from a traditional transponder to a Garmin GTX-335 ticks were introduced into the audio.  I've got an otherwise very tight and well performing audio install with very careful consideration of grounds, returns etc.
I've debugged enough to be *quite* certain that the interference path is from the energy radiated off of the antenna itself into the mic circuitry on my panel mount Sigtronics intercom.
If you google a bit, you will discover that there are many people who similarly had ticks introduced into their audio once they upgraded their 1090 MHz transponder to being ADS-B out capable.
Though I believe  the real fix in my install will be to make my intercom less sensitive to RF Field pulses, I'm still not considering moving my transponder antenna inside as it would certainly make the problem worse...  I might consider it in the future once I mitigate the tick issue with it in its current location.
Steve Stearns
Longeze N45FC
Boulder/Longmont CO.
Airdog77
PostPosted: Mon Nov 13, 2017 9:04 am    Post subject: Re: Transponder antenna Reply with quote
Steve,
Good to know!
And clearly, this is a lesson for me to be more clear... Smile
Although I know you're talking about the "old style" antenna, I plan on mounting the L2 antenna at the outboard end of the strake at the junction with the wing. Still quite a ways from the comm antenna in the vertical winglet, but also a decent ways out from the pilot/GIB and cabin electronics.
Wade
Airdog
Wade Parton
www.longezpush.com
berkut13(at)berkut13.com
PostPosted: Fri Nov 24, 2017 8:10 am    Post subject: Transponder antenna Reply with quote
So the noise is breaking intercom squelch?
I’ve noticed that in many EZ type installations, the transponder RF “clicking” noise is actually getting in to the headset itself. Especially if it is the active noise canceling variety. It didn’t seem to matter what intercom was being used, VOX system shielding, ground separation and even ferrite chokes added to the power/coax/audio lines...or even transponder. In one case I could even unplug the headset and still get the noise.
Mostly, I found that I can get the intensity of the noise to change (and even disappear in some positions) as I rotate my head (with headset on) or move to different parts of the cabin and/or moving the control box around. It can be replicated on the ground as well if you are in an active surveillance area and can get your transponder to be active.
Try that and using a different brand and type of headset and see if you have similar results. If so, there is not much you can do about it but change headset vendor/type if you find a quiet one or increase the size of the ground plane if you have the room – which is quite limited in an EZ.
Let us know what you find.
-James
Berkut/Race 13
Sent: Monday, November 13, 2017 8:43 AM
Subject: Re: Re: Transponder antenna
meyerkc135(at)gmail.com
PostPosted: Fri Nov 24, 2017 5:37 pm    Post subject: Transponder Antenna Reply with quote
Bob, etc all.,Thank you.
For the short term, I bought a piece of 1/8" brass rod, turned down and soldered the old connector to this rod, put the ball on the end and installed... Going to test fly tomorrow. Matched the length, etc...
I will explore the internal options shortly. Slowly getting rid of drag. Need to do it faster though.
Happy Flyin'!
Andy
