z13/8 ess bus feed
mmcelrea
PostPosted: Sat Nov 11, 2017 3:49 pm    Post subject: z13/8 ess bus feed Reply with quote
Hi. Building an RV7 in the UK with a G3X system and thinking of using the z13/8 architecture with the SD8 backup alt and GAD27 to maintain voltage to the GDU etc during engine start. Is it normal or acceptable to keep the essential bus alternate feed on during flight in case of battery contactor failure? I'd rather not add a second battery. I'm thinking of the scenario in case the battery contactor fails then both busses would be offline. How can power be maintained to the essential bus without a backup battery?
PostPosted: Sun Nov 12, 2017 4:56 pm    Post subject: z13/8 ess bus feed Reply with quote
At 05:49 PM 11/11/2017, you wrote:
--> AeroElectric-List message posted by: "mmcelrea" <mmcelrea(at)hotmail.com>
Battery contactors seldom fail in fight . . . I use
the word 'seldom' because the rate is fanishingly
small. I've never encountered such a failure.
A contactor on the edge of failure will raise caution
flags by causing fussy starts or failure to close
during start up.
Even if it does fail, you probably wouldn't know it
until the next preflight.
The airplane will continue to run on the self
excited alternator. But if you want to fly around with
the alternate feed switch closed, it doesn't hurt
anything but it's unnecessary.
mmcelrea
PostPosted: Mon Nov 13, 2017 3:16 am    Post subject: Re: z13/8 ess bus feed Reply with quote
Thankyou Bob
I am building the aircraft with approval for IFR flight here in the UK and the LAA are concerned about single failure points. Using the Z13.8 architecture is it possible to monitor if the backup alternator is working, even if its not supplying?
PostPosted: Mon Nov 13, 2017 1:19 pm    Post subject: z13/8 ess bus feed Reply with quote
Thankyou Bob
Not really . . . but demonstrated failure rates
on the SD8 used in standby service is essentially
zero. The system runs stone cold in normal flight
meaning that thermal wear/tear on components and materials
is zero, there are no brushes or slip rings. Further
system is both pre-flight and in=flight testable.
Don't know how you would get better reliability
numbers on an engine driven power source.
mmcelrea
PostPosted: Wed Nov 15, 2017 12:50 am    Post subject: Re: z13/8 ess bus feed Reply with quote
Is the SD8 on/available during normal flight? If the output is fed through a diode would that prevent the alternators 'competing' or is the voltage set at lower level than the main alternator and monitoring voltage and amps output from both alternators?
PostPosted: Wed Nov 15, 2017 8:47 am    Post subject: z13/8 ess bus feed Reply with quote
You can run it during normal flight . . . but why?
It's a STANDBY alternator that demonstrates exceptional
reliability by sitting there doing NOTHING until
pressed into service as a consequence of main
alternator failure.
It should be pre-flight tested . . . but allowed
to sit in cold repose waiting for the rare failure
of the main alternator.
mmcelrea
PostPosted: Fri Nov 24, 2017 12:35 pm    Post subject: Re: z13/8 ess bus feed Reply with quote
Is it acceptable to use cb's, fuses or limiters in place of the fuse links from the stby alternator, main bus to master and the alternate essential bus feed? Also is it ok to use 1 amp fuses in place of fuse links from the shunts on a G3X system?
PostPosted: Sat Nov 25, 2017 10:37 am    Post subject: z13/8 ess bus feed Reply with quote
Sure. Fusible links are simply a low cost, lower parts
count, convenient substitute for the LONG TIME CONSTANT
current limiter. Fusible links and current limiters target
the battery-driven, hard fault condition.
For your purposes, you can replace ANY fusible link
shown in the drawings with a fuse or circuit breaker
but I suggest that it only adds to cost and labor.
But it's not 'unacceptable'.
I would avoid using fuses lower than 3A for
mechanical robustness concerns . . . in fact,
for airplanes wired with nothing smaller than
22AWG, a 5A fuse is a practical lower limit
for fuse selection.
