Cleveland Wheel Bearings
Dave Saylor
PostPosted: Tue Nov 07, 2017 4:29 pm    Post subject: Cleveland Wheel Bearings Reply with quote
Does anyone have a good source for wheel bearings?  I found Timken nose bearings for about $40 but the my shopping cart at Vans is running about $650 for all 8 pcs for the mains.  I'm pretty sure it doesn't have to be this way.  But my search for LM274949-2-629 is coming up short.
Has someone had success with an alternate number?  Besides the Cleveland number?
--Dave
--Dave
KWVI
Don Orrick
PostPosted: Tue Nov 07, 2017 5:19 pm    Post subject: Cleveland Wheel Bearings Reply with quote
Local auto parts store can order them or a local bearing supply co can get them
--Dave
toaster73(at)embarqmail.c
PostPosted: Tue Nov 07, 2017 6:01 pm    Post subject: Cleveland Wheel Bearings Reply with quote
I'll second the possible auto parts angle the following is my order from a few years ago after hurricane high water got on my wheels and I couldn't get them apart in time to prevent corrosion.
These aren't the FAA/PMA flavor but they have been running fine for 300 hours and 4 conditional inspections. Double check the numbers and my research.
-Chris
N919AR
Motion Industries
Release No:                             Date:         10/13/2011
F.O.B:        FOB ORG,FRT PP&ADD
Terms:        .         CASH
Delivery:     STOCK UNLESS NOTED
Qty    Description                                          Requested Date
  4.0    TIMKEN       LM29749 CONE                               10/19/2011
                    Item No..........: 00658750
                    Cust Stk No .....:
                    Price............: 15.120                      60.48
  4.0    TIMKEN       LM29710 CUP                                10/19/2011
                    Item No..........: 00658736
                    Cust Stk No .....:
                    Price............: 9.360                        37.44
                              SUBTOTAL                           97.92
                              FREIGHT*                            9.89
                              TAX                                 7.28
                              TOTAL**                           115.09
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Saylor
Sent: Tuesday, November 07, 2017 7:27 PM
Subject: Cleveland Wheel Bearings
--Dave
Tim Olson
PostPosted: Tue Nov 07, 2017 6:09 pm    Post subject: Cleveland Wheel Bearings Reply with quote
Yeah I've taken them in to a local place in town before
called "Bearing Headquarters" and they can get just
about anything.
> Thanks,
> --Dave
Kellym
PostPosted: Tue Nov 07, 2017 7:11 pm    Post subject: Cleveland Wheel Bearings Reply with quote
Once you get replacements, be aware that Cleveland has changed their
grease recommendations. Aeroshell #5 is no longer 1st choice.
First choice is Mobil SHC 100, which is a red synthetic grease.
Skygeek carries an appropriate sized tube. The rest of suppliers, last I
looked only carry 5 lbs and up.
I do not know reason Cleveland changed their recommendation.
Kelly
about anything.
> get them
> Sent from my iPhone
>> coming up short.
>> Cleveland number?
>> Thanks,
>> --Dave
Kelly McMullen
KCHD
Dave Saylor
PostPosted: Tue Nov 07, 2017 8:02 pm    Post subject: Cleveland Wheel Bearings Reply with quote
Thank you Chris, that's just what I needed.  --Dave
On Tue, Nov 7, 2017 at 6:00 PM, Chris <toaster73(at)embarqmail.com (toaster73(at)embarqmail.com)> wrote:
-Chris
N919AR
Motion Industries
Terms:        .         CASH
                    Cust Stk No .....:
                    Cust Stk No .....:
                              SUBTOTAL                           97.92
                              FREIGHT*                            9.89
                              TAX                                 7.28
                              TOTAL**                           115.09
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David Saylor
Subject: RV10-List: Cleveland Wheel Bearings
--Dave
--Dave
KWVI
Mauledriver(at)nc.rr.com
PostPosted: Wed Nov 08, 2017 7:01 am    Post subject: Cleveland Wheel Bearings Reply with quote
Request for background: What kind off experience have people had with
failing/damaged/rusting wheel bearings vis-a-vis maintenance of wheel
bearing?
I operate off a sometimes wet and mushy field where my wheels get quite
a dousing.  Each condition inspection, I've been repacking the
bearings.  So far I have seen any signs of rusting - is there something
else I should be looking for?
Bill "6 years and 900+ hours on same bearings, color me curious" Watson
short.
Cleveland number?
--Dave
Dave Saylor
PostPosted: Wed Nov 08, 2017 7:51 am    Post subject: Cleveland Wheel Bearings Reply with quote
Right, SHC 100 looks a lot like Mobil 28 but it's lighter red IIRC.  I used it last year.
--Dave
On Tue, Nov 7, 2017 at 7:09 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Once you get replacements, be aware that Cleveland has changed their grease recommendations. Aeroshell #5 is no longer 1st choice.
Skygeek carries an appropriate sized tube. The rest of suppliers, last I looked only carry 5 lbs and up.
Kelly
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
about anything.
--> RV10-List message posted by: Don Orrick <don.orrick(at)yahoo.com (don.orrick(at)yahoo.com)>
On Nov 7, 2017, at 6:26 PM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
--Dave
--Dave
KWVI
Dave Saylor
PostPosted: Thu Nov 09, 2017 7:48 am    Post subject: Cleveland Wheel Bearings Reply with quote
Bill,
I'll send some pictures of the bearings I'm replacing. The rollers and cones are pitted.
If what you're doing is keeping the bearings in good shape, just keep doing it. It's pretty obvious when they fail.  In my experience, once the cup or a roller shows even the tiniest pit/mark/dent/chip, it only takes a few hours of operation to go from "I could probably live with that" to "get that thing off my plane".
--Dave
On Wed, Nov 8, 2017 at 6:59 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Request for background: What kind off experience have people had with failing/damaged/rusting wheel bearings vis-a-vis maintenance of wheel bearing?
I operate off a sometimes wet and mushy field where my wheels get quite a dousing.  Each condition inspection, I've been repacking the bearings.  So far I have seen any signs of rusting - is there something else I should be looking for?
--Dave
--Dave
KWVI
