NavWorx software version
hilltopkid
PostPosted: Wed Nov 08, 2017 9:10 am    Post subject: NavWorx software version Reply with quote
We have a NavWorx ADS600-B box in our not yet flying Sportsman which I’d like to keep. We also have a GTN650, so that can be our position source. I understand that is possible and that at least one person has received an Alternate Method of Compliance approval from the FAA which allows certified Garmin boxes for the position source. However, here is what I’m not sure about. My question is how do I rind the version of the software? And what version must we have in order to fly using the GTN650 as the position source? We sent our box back to Bill Moffitt (no charge, just UPS back and forth) in August 2016 at which point he, I think, installed the GPS chip which we now know is not acceptable to the FAA.
Thanks.
Dee Whittington
Sportsman 7034
DeWitt (Dee) Whittington
Richmond, VA
recapen(at)earthlink.net
PostPosted: Wed Nov 08, 2017 10:43 am    Post subject: NavWorx software version Reply with quote
The NavWorx 4.1 software is the latest one available that I know of - it can no longer be obtained from NavWorx - but it is out there
As for the GTN650 - make sure it supports ADS-B OUT+. You should be able to find it in the serial configuration of the GTN650...or contact Garmin.
hilltopkid
PostPosted: Wed Nov 08, 2017 12:12 pm    Post subject: NavWorx software version Reply with quote
Thanks, Ralph,
So, how do I check the version of our software? As I said in the previous post, we sent our unit back to Bill in late July or early August, 2016. I’d suppose he would have updated the software then as well as installing the GPS chip.
As for our GTN650 supporting ADS-B Out, thought all 650s would be ready for ADS-B. Anyhow, I’ll check with John Stark who sold us the unit, and if he doesn’t know, I’ll get in touch with Garmin.
Dee
[quote] On Nov 8, 2017, at 1:42 PM, Ralph E. Capen <recapen(at)earthlink.net> wrote:
Richmond, VA
PostPosted: Wed Nov 08, 2017 2:48 pm    Post subject: NavWorx software version Reply with quote
Dee,
For the GTN650, it should display the software rev at startup.
For the ADS600B, connect a serial cable to the maintenance port on the ADS600B - the other end goes in to your computer/laptop/etc. Start the NavWorx UAT console (4.1) and select the correct logical comm port for your computer. It may not connect the first time - so retry another logical comm port. When it connects, it will tell you what software you have or force an upgrade to the 4.1. If it connects directly, it will tell you that it is 4.1 already.
Ralph
hilltopkid
PostPosted: Wed Nov 08, 2017 6:35 pm    Post subject: NavWorx software version Reply with quote
Thanks,  Ralph, for the help. I'll speak to my partners and get this done. I vaguely remember doing this several years ago. Never thought we'd have to do it again.
Dee
DeWitt (Dee) WhittingtonRichmond, VA
804-677-4849 iPhone
804-358-4333 Home
On Wed, Nov 8, 2017 at 5:46 PM, Ralph E. Capen <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
[quote]--> AeroElectric-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
Dee,
Ralph
Richmond, VA
