912 UL Intake Manifold Pressures
italianjon
PostPosted: Fri Oct 20, 2017 11:28 am    Post subject: 912 UL Intake Manifold Pressures Reply with quote
Hi All,
I've been tracking a vibration for a while, and it has been very difficult. Carburettors have been sync'd more than I've had hot dinners, plus other areas of the engine. So far I've eliminated the propeller, gearbox
I noticed a strange effect today, and I'm unsure about it. Today, as a result of a vibration plot taken last weekend, decided to carefully check the carburettor sync again. The vibration plot is showing the vibration at half-crank and twice-crank frequency.
I connected two vacuum gauges, so that I am reading absolute vacuum (i.e. 0" is ambient and 10", for example, is 10" of vacuum).
From about 10" up to 0", which corresponds to rpms of about 3400 up to 5400, the carburettors are in sync. Below that they aren't.
At idle of about 1750/1800 rpm i get 12.5-13" in the port carb, and 15.5" in the starboard carb.
I found Roger Lee's very good guide and thought that I could take out this idle difference with the idle mixture screw. But it didn't really change anything, no matter where set on the port carb. On the starboard carb it did have an effect.
The other strange symptom that I found is that if I take the engine to a fair speed, say 4000 rpm and then quickly idle the throttle, then both carbs come down to 15" in sync before the port carb raises to 12.5/13".
Compressions were checked 12 months ago, all ok. Carburettors we overhauled 12 months ago, all ok. Carb mounts renewed 12 months ago.
Any one seen this effect before?
I'm thinking of taking off the manifold and checking the O-rings between the engine and manifold for leaks. And also stripping back the carbs, cleaning and rebuilding them.
Anything else I should be thinking?
Best
Jon
williamtsullivan(at)att.n
PostPosted: Fri Oct 20, 2017 1:08 pm    Post subject: 912 UL Intake Manifold Pressures Reply with quote
Check the Viton seals in the enrichers. One could be deteriorating. Cheap and easy fix, if that's it.
On Fri, 10/20/17, italianjon <jon.catilli(at)gmail.com> wrote:
Subject: 912 UL Intake Manifold Pressures
Date: Friday, October 20, 2017, 3:28 PM
"italianjon" <jon.catilli(at)gmail.com>
Hi All,
gearbox
did have an effect.
12.5/13".
rebuilding them.
Best
Jon
http://forums.matronics.com/viewtopic.php?p=473713#473713
The RotaxEngines-List Email Forum -
Navigator to browse
List Un/Subscription,
7-Day Browse, Chat, FAQ,
    - MATRONICS WEB FORUMS -
via the Web Forums!
    - NEW MATRONICS LIST WIKI -
Email List Wiki!
  - List Contribution Web Site -
support!
klinefelter.kevin(at)gmai
PostPosted: Fri Oct 20, 2017 8:22 pm    Post subject: 912 UL Intake Manifold Pressures Reply with quote
To check the intake manifolds for leaks you can spray ether around them with the engine running. If the RPM goes up you have a leak.
Kevin
On Oct 20, 2017, at 2:06 PM, william sullivan <williamtsullivan(at)att.net> wrote:
Hi All,
gearbox
did have an effect.
12.5/13".
rebuilding them.
Best
Jon
Navigator to browse
via the Web Forums!
Email List Wiki!
support!
davidjoyce(at)doctors.org
PostPosted: Sat Oct 21, 2017 1:09 am    Post subject: 912 UL Intake Manifold Pressures Reply with quote
Jon, I believe I had a rather similar thing quite a few years ago when my throttle cables were run in a not symmetrical pattern with one following tighter bends. Regards, David Joyce, GXSDJ
On 2017-10-20 20:28, italianjon wrote:
--> RotaxEngines-List message posted by: "italianjon" <jon.catilli(at)gmail.com (jon.catilli(at)gmail.com)>
Hi All,
I connected two vacuum gauges, so that I am reading absolute vacuum (i.e. 0" is ambient and 10", for example, is 10" of vacuum).From about 10" up to 0", which corresponds to rpms of about 3400 up to 5400, the carburettors are in sync. Below that they aren't.At idle of about 1750/1800 rpm i get 12.5-13" in the port carb, and 15.5" in the starboard carb.
Best
Jon
ist">http://www.matronics.com/Navigator?RotaxEngines-List
ics.com
.com
.matronics.com/contribution
brian.davies(at)clara.co.
PostPosted: Sat Oct 21, 2017 4:49 am    Post subject: 912 UL Intake Manifold Pressures Reply with quote
Sticking throttle cables?
Brian Davies
Roger Lee
PostPosted: Sun Oct 22, 2017 5:20 am    Post subject: Re: 912 UL Intake Manifold Pressures Reply with quote
Hi Jon,
Give me a call and let's see if we can work this out and eliminate a few things. I need to ask some questions.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
