digidocs
Posted: Tue Oct 17, 2017 2:27 pm Post subject: Pitot mast tie down clearance |
Hi guys,
Has anyone had tie down rope clearance issues when mounting the pitot mast on the inboard side of the rib just outboard of the aileron bellcrank?
That's a bit of a tongue twister, so here's a picture that shows what I'm talking about (pitot is outboard side of bellcrank):
https://tinyurl.com/y76l4cq3
David
philperry9
Posted: Tue Oct 17, 2017 2:59 pm Post subject: Pitot mast tie down clearance |
I’ve only got a few hours on mine and noticed it in a recent trip. It really depends on the width of the tie down points. If they’re narrow, then yeah. If they’re wide, then no.
But if I moved the mast outboard I’d still have problems at those places too. So it’s as broad as it is long.
I don’t think it’s worth the trouble to reinvent a location and move it from the standard location.
On Oct 17, 2017, at 5:25 PM, David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
| Quote: | Hi guys,
David
Tim Olson
Posted: Tue Oct 17, 2017 3:28 pm Post subject: Pitot mast tie down clearance |
I did the same....pitot is one bay further out.
Tim
On Oct 17, 2017, at 5:57 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
| Quote: | I’ve only got a few hours on mine and noticed it in a recent trip. It really depends on the width of the tie down points. If they’re narrow, then yeah. If they’re wide, then no.
| Quote: | Hi guys,
David
dmaib(at)mac.com Guest
Posted: Tue Oct 17, 2017 5:01 pm Post subject: Pitot mast tie down clearance |
Mine are in the standard location and I’ve never had any tie down clearance issues in 9 years and nearly 1000 hours. Narrow or wide doesn’t seem to make a difference. I figured Van’s had flight tested the prototype with the pitot in that location, so the odds of having pitot/static accuracy issues would be minimized if I followed the plans on that particular issue.
David Maib
40559
985 hours
On Oct 17, 2017, at 6:57 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
| Quote: | Hi guys,
David
philperry9
Posted: Tue Oct 17, 2017 5:09 pm Post subject: Pitot mast tie down clearance |
It’s not an accuracy issue. It’s the rope running into the pitot tube of the tie down points on the ground are narrow....
On Oct 17, 2017, at 8:00 PM, David Maib <dmaib(at)mac.com (dmaib(at)mac.com)> wrote:
| Quote: | Mine are in the standard location and I’ve never had any tie down clearance issues in 9 years and nearly 1000 hours. Narrow or wide doesn’t seem to make a difference. I figured Van’s had flight tested the prototype with the pitot in that location, so the odds of having pitot/static accuracy issues would be minimized if I followed the plans on that particular issue.
David Maib
40559
985 hours
| Quote: | Hi guys,
David
Posted: Tue Oct 17, 2017 5:19 pm Post subject: Pitot mast tie down clearance |
I understand the issue. Just putting in my $.02 worth and stating why I made the decision at the time.
David Maib
On Oct 17, 2017, at 9:08 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
It’s not an accuracy issue. It’s the rope running into the pitot tube of the tie down points on the ground are narrow....Sent from my iPhone
David Maib
40559
985 hours
| Quote: | Hi guys,
David
