RotaxEngines-List Digest: 1 Msgs - 10/09/17
johnelling
PostPosted: Tue Oct 10, 2017 12:13 am    Post subject: RotaxEngines-List Digest: 1 Msgs - 10/09/17 Reply with quote
Right.  A few  weak  revolutions at best.  Often no revolutions at all.
On 10/10/2017 8:03 PM, RotaxEngines-List Digest Server wrote:
I had a similar-sounding problem with my Rotax 912ULS. It turned out to be the
sprag clutch. When the problem began, the engine started better when warm but
would not start when cold. When I finally changed it out, I found metal in
it.
What was the problem? Was the engine not turning over fast enough?
max8992
PostPosted: Tue Oct 10, 2017 12:39 am    Post subject: RotaxEngines-List Digest: 1 Msgs - 10/09/17 Reply with quote
Yes probably. Got the same on same type of engine and before changing the only way to start it when cold was to put a second battery to boost at 24V and make it turning faster...
Max8992
Europa XS #560 F-PMLH
