		Yak Driver
				 Posted: Tue Sep 12, 2017 2:58 am    Post subject: Baklan won't transmit |
				Hi Yakkers,
 I have the original baklan radio in my Yak 18T - series II. I can hear other aircraft, the intercom works fine but when I try and transmit via the PTT switch no one can hear me. It drops a carrier wave but there is no audible transmission coming through. It is the same on both sides. Has anyone had a similar fault?
 Thanks in advance.
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		wlannon(at)shaw.ca Guest
				 Posted: Tue Sep 12, 2017 8:17 am    Post subject: Baklan won't transmit |
				Try a different mic. before you trash the radio.
		rocknpilot(at)hotmail.com Guest
				 Posted: Tue Sep 12, 2017 9:36 am    Post subject: Baklan won't transmit |
				I had this exact same thing happen a year ago. The FBO / other aircraft said they could detect the carrier wave but no audio. Upon inspection, one of the wires had let go on my helmet / headset jacks. 2 minutes of soldering later...VOILA!
 It may be worth a look...
 GOOD LUCK!
     Rico Jaeger
  915 S. 11th Ave.
  Wausau, WI. 54401
  715.529.7426
  1969 Cessna 150J                            ^/---//-X
  N61333                                                  // Hangar #35 / AUW
  1992 Yakovlev Yak 52    ^/---//-X
  N21YK                                   //
  Hangar #21 / AUW
   From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of Walter Lannon <wlannon(at)shaw.ca>
  Sent: Tuesday, September 12, 2017 11:15:45 AM
  To: yak-list(at)matronics.com
  Subject: Re: Baklan won't transmit
   --> Yak-List message posted by: "Walter Lannon" <wlannon(at)shaw.ca>
		pilko2(at)btinternet.com Guest
				 Posted: Wed Sep 13, 2017 2:23 am    Post subject: Baklan won't transmit |
				Take a good look at the PTT button before you go much further.
 I've had at least three fail.
 kp
		LawnDart
				 Posted: Thu Sep 14, 2017 11:24 am    Post subject: Re: Baklan won't transmit |
				I seen this happen a few times.  Once with my radio.  I could hear the radio go into XMIT however there was no sidetone.
 IIRC there are fuses on the tray at the rear. However we had to send the radio in for repair.
 Leonid
 858-578-2311
 If that contact info does not work, contact Jill(at)M-14P
				 Posted: Fri Sep 15, 2017 11:24 am    Post subject: Baklan won't transmit |
				Actually, that is a very good point that I totally forgot.    It is important to know whether the airplane with the gripe has good sidetone (as in: When you push the transmit PTT switch,  can you hear yourself speak in your headset earphones?)
 I am not 100% sure with this radio, but with EVERY other radio that I have worked on/with, sidetone was actually generated in the radio itself.  Which means if you can hear yourself talk in your headset when transmitting, then your microphone audio is making it to the radio.   If you then have no modulation on the transmitted signal and instead just carrier (and you VERIFY that it has carrier) then the odds pretty much say it must be the radio itself.
 Wish I had remembered this before writing the last mess.
 Thanks Leonid.
 Mark
