bakerocb
Posted: Sat Sep 30, 2017 6:18 pm Post subject: Main spar bolt? |
9/30/2017
Hello Stephen, The builders manual for the KIS TR-1 calls for the fuselage
main spar box hat shaped bushings (KS-19) to be solidly bonded into place in
the spar box with flox/micro slurry.
Similarly, the wing main spar tubular bushings (KS-1 are to be solidly
bonded into place in the wing forward (main) spar with flox/micro slurry.
See pages ASSY-2 and ASSY-3 of the builders manual.
If these bushings are turning when you turn the the AN8-46 bolts that hold
the forward wing spar into the fuselage spar box then your wing is not
securely fastened to the fuselage.
OC
Sent: Saturday, September 30, 2017 12:30 PM
To: Mark Trickel ; bakerocb(at)cox.net
Subject: Main spar bolt?
Hi Mark & O C
I reinstalled the wing today and after torquing the two front mains spar
bolts. I lifted the wing out at the end on the right side a little and heard
a clicking. After examining the right side main spar bolt. I noticed the
whole bolt turns in the spar Is this normal or do I have a major
problem???
To our success, Stephen McIntosh
bakerocb
Posted: Sun Oct 01, 2017 7:00 am Post subject: Main spar bolt? |
10/1/2017
Hello Stephen, To follow up please see the two attachments.
OC
Sent: Saturday, September 30, 2017 10:17 PM
To: pastormac(at)comcast.net ; KIS-LIST MATRONICS
Subject: Re: Main spar bolt?
9/30/2017
OC
Hi Mark & O C
problem???
 Download |
| Filename: |
BUSHING_PLACEMENT_A.docx |
59.15 KB |
| Downloaded: |
779 Time(s) |
 Download |
| Filename: |
MOUNTING_WING_B.docx |
16.19 KB |
| Downloaded: |
738 Time(s) |
pastormac62
Posted: Sun Oct 01, 2017 9:08 am Post subject: Main spar bolt? |
Thanks! I torqued the main spar bolts to 45 ft lbs? Is that correct??
To our success,
Stephen McIntosh
| Quote: | On Oct 1, 2017, at 10:59 AM, OC <bakerocb(at)cox.net> wrote:
10/1/2017
OC
9/30/2017
OC
Hi Mark & O C
problem???
<BUSHING PLACEMENT A.docx>
<MOUNTING WING B.docx>
hansoncp(at)netnitco.net Guest
Posted: Sun Oct 01, 2017 2:39 pm Post subject: Main spar bolt? |
Steve, If the bolt is turning in the bushings you may be bottoming out on
the threads and need some washers.
pastormac62
Posted: Sun Oct 01, 2017 3:09 pm Post subject: Main spar bolt? |
Thanks Ed!!
[quote] On Oct 1, 2017, at 6:38 PM, Ed Hanson <hansoncp(at)netnitco.net> wrote:
Steve, If the bolt is turning in the bushings you may be bottoming out on the threads and need some washers.
Keith.Miller(at)esa.int Guest
Posted: Sun Oct 01, 2017 11:31 pm Post subject: Main spar bolt? |
I never found anywhere in the instructions on how much to torque the nuts to
for the main spar bolts.
If it was all built correctly, the idea was that the hat shaped washers
(which are bonded into the spar box ) would be a perfect fit against the
spacers running through (and bonded) the wing spars. The bolts are
essentially just holding it all in place and loaded in shear ) . They have
a nylock insert on the nuts anyway to stop them from sliding out .
In my installation I have a washer at the both the bolt head and the nut
sides to complete the installation, resulting in 1.5 threads showing on the
threads when it is assembled. So far in 16 years they have remained tight,
and i have no movement when the wings are lifted at the outboard ends
I would as Ed suggests, investigate if the nut is bottoming out , How many
threads are showing ?
It would still be unusual to have any movement of these bolts in any
direction , even if they are bottoming out
Keith
To: kis-list(at)matronics.com
Date: 01/10/2017 19:09
Subject: Re: Fw: Main spar bolt?
Sent by: owner-kis-list-server(at)matronics.com
To our success,
Stephen McIntosh
10/1/2017
OC
9/30/2017
in
| Quote: | the spar box with flox/micro slurry.
OC
Hi Mark & O C
heard
| Quote: | a clicking. After examining the right side main spar bolt. I noticed the
problem???
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
pastormac62
Posted: Mon Oct 02, 2017 3:52 am Post subject: Main spar bolt? |
I believe I need to add a few more washers. I have 4 threads showing. Must be bottoming out.
Keith
To our success,
Stephen McIntosh
> 10/1/2017
> OC
> From: OC
> 9/30/2017
in
> OC
> From: pastormac(at)comcast.net
> Hi Mark & O C
heard
> problem???
