Oil Filters
kearney
PostPosted: Fri Aug 25, 2017 1:07 pm    Post subject: Oil Filters Reply with quote
Hi
Now that we have flogged spark plugs to death, is there any consensus as to the preferred oil filter - Champion or Tempest?
Cheers
Les
C-GCWZ Flying
C-GROK Some assembly required
philperry9
PostPosted: Fri Aug 25, 2017 1:18 pm    Post subject: Oil Filters Reply with quote
Running my last Champion now and switching to Tempest. Better and cheaper.
https://youtu.be/N22sAS80_Js
https://youtu.be/4lH_sg121os
On Aug 25, 2017, at 4:07 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Cheers
Les
C-GCWZ Flying
http://forums.matronics.com/viewtopic.php?p=472186#472186
<==========================; - The RV10-List Email Forum -http://www.matronics.com/Navigator?RV10-List
http://wiki.matronics.com<==========================; - List Conbsp;   -Matt Dralle, List Ads.com/contribution">http://www.matronics.com/contribution[/url]
Tim Olson
PostPosted: Fri Aug 25, 2017 1:54 pm    Post subject: Oil Filters Reply with quote
Yep, I only use tempest oil filters, too.
Tim
cheaper.
> Hi
> Cheers
> Les
> C-GCWZ Flying
> http://forums.matr====================================================nbsp;-->
> <http://wiki.matronics.com>
kearney
PostPosted: Fri Aug 25, 2017 2:02 pm    Post subject: Re: Oil Filters Reply with quote
Watched the videos (thanks Phillip) and am sold!
Cheers
Les
jesse(at)saintaviation.co
PostPosted: Fri Aug 25, 2017 2:19 pm    Post subject: Oil Filters Reply with quote
Phillips oil, Tempest filter and Tempest plugs.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
Tim
> cheaper.
> Sent from my iPhone
>> Hi
>> Cheers
>> Les
>> C-GCWZ Flying
Mauledriver(at)nc.rr.com
PostPosted: Fri Aug 25, 2017 2:37 pm    Post subject: Oil Filters Reply with quote
Model number?
Bill "feeling lazy" Watson
Hi
Cheers
Les
C-GCWZ Flying
http://forums.matr====================================================nbsp;--> http://wiki.matronics.com<==========================;           - List Conbsp;                     -Matt Dralle, List Ads.com/contribution">http://www.matronics.com/contribution
tsts4
PostPosted: Fri Aug 25, 2017 2:41 pm    Post subject: Re: Oil Filters Reply with quote
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Same here plus Camguard
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
philperry9
PostPosted: Fri Aug 25, 2017 2:47 pm    Post subject: Oil Filters Reply with quote
I'm probably the wrong person to ask, since I have the Airwolf Remote Oil Filter mounted on to my firewall.   Mine is a 48109-1, but I don't think that's the one commonly used if you're mounting in the normal location of the D4A5.
On Fri, Aug 25, 2017 at 5:35 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
Model number?
Hi
Cheers
Les
C-GCWZ Flying
Virus-free. www.avast.com [url=#m_3678380936954703690_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Lenny Iszak
PostPosted: Fri Aug 25, 2017 2:51 pm    Post subject: Re: Oil Filters Reply with quote
Sam as Jesse + Camguard.
Model# Tempest AA48110-2
Tim Olson
PostPosted: Fri Aug 25, 2017 3:22 pm    Post subject: Oil Filters Reply with quote
Whatever your old model number is, is what your new model number is, basically.
Tim
On Aug 25, 2017, at 5:35 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
Model number?
Hi
Cheers
Les
C-GCWZ Flying
Kelly McMullen
PostPosted: Fri Aug 25, 2017 4:24 pm    Post subject: Oil Filters Reply with quote
The part number is valid only for genuine Lycoming filter adapter.
Most after market adapters such as B&C, Casper, ADC use different
filter #
Tempest is certainly the market leader.
-sent from the I-droid implanted in my forearm
On Fri, Aug 25, 2017 at 3:51 PM, Lenny Iszak <lenard(at)rapiddecision.com> wrote:
http://forums.matronics.com/viewtopic.php?p=472195#472195
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
PostPosted: Fri Aug 25, 2017 4:49 pm    Post subject: Oil Filters Reply with quote
I should have added CamGuard to the list. I won't go without it.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
filter #
Tim Olson
PostPosted: Fri Aug 25, 2017 6:00 pm    Post subject: Oil Filters Reply with quote
We think alike. Phillips + camguard is where I'm at too.
Tim
Jesse Saint
C: 352-427-0285
F: 815-377-3694
> filter #
dmaib(at)mac.com
PostPosted: Fri Aug 25, 2017 7:40 pm    Post subject: Oil Filters Reply with quote
Phillips oil + Camguard and Tempest filters and Tempest fine wire plugs on the bottom. That's my story and I'm sticking to it. (Nearly 1000 hours!)
David Maib
Tim
> Jesse Saint
> C: 352-427-0285
> F: 815-377-3694
> Sent from my iPhone
>> filter #
>>> Read this topic online here:
philperry9
PostPosted: Fri Aug 25, 2017 7:47 pm    Post subject: Oil Filters Reply with quote
Curious to know why so few are running Aeroshell? W100Plus with the corrosion protection additive already in the bottle....
Is there some data out there that I need to be aware of?
Phil
David Maib
> Tim
>> Jesse Saint
>> C: 352-427-0285
>> F: 815-377-3694
>> Sent from my iPhone
>>> filter #
Kellym
PostPosted: Fri Aug 25, 2017 7:54 pm    Post subject: Oil Filters Reply with quote
Yes. The additive in the "Plus" versions and 15W50 is not specifically
anti-corrosion. It is the Lycoming extreme pressure lubricant, which is
only required for "76 Series" engines such as the O-320-H2AD used in 77
and later C-172s.
Exxon Elite or any oil with Camguard is far better than anything
Aeroshell offers without Camguard.
Phil
> David Maib
>> Tim
>>> Jesse Saint
>>> C: 352-427-0285
>>> F: 815-377-3694
>>> Sent from my iPhone
>>>> filter #
Kelly McMullen
KCHD
philperry9
PostPosted: Fri Aug 25, 2017 8:38 pm    Post subject: Oil Filters Reply with quote
Bill,
I see you're famous!
https://youtu.be/zLi8BG2PahE?t=7m25s
Model number?
Hi
Cheers
Les
C-GCWZ Flying
Virus-free. www.avast.com [url=#m_-8857746378743614217_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Tim Olson
PostPosted: Fri Aug 25, 2017 8:51 pm    Post subject: Oil Filters Reply with quote
I actually used to use Exxon Elite all the time, and then when camguard
came out
I added that to it. I still had some cases of it left so in the winter
I used it
with camguard last year, just because Exxon Elite was supposed to also
be more anti-corrosion. But after Aviation Consumer came out with their
oil testing with Camguard and said that Philips + Camguard was the best
bargain, I started going that route. Philips costs less, and is
available locally
only 20 minutes away from an oil supplier in town. I would probably be
happy
to use Exxon Elite in the winters along with camguard. The one thing
that keeps
me with just Philips is that I've always heard in cars at least that
synthetics
can lead to hardening of seals. I figure if sticking with non-synthetics
can help prevent hardening, and Camguard prevents corrosion, that should
be a good way to go. I know all of the local FBO's around me for all nearly
20 years that I've been flying, have all been Philips, and they seem to
get great
life out of their planes. So, I'm comfortable with it for sure.
Tim
is only required for "76 Series" engines such as the O-320-H2AD used
in 77 and later C-172s.
PostPosted: Sun Aug 27, 2017 6:20 am    Post subject: Oil Filters Reply with quote
Thanks So Much!!  We were wondering if we'd ever see any of the video
that was being shot.  He caught us in a moment of ecstasy it looks like.
It was a very cool event all around!
Bill "needs to learn how to link to 7m25s like that" Watson
On 8/26/2017 12:36 AM, Phillip Perry wrote:
Bill,
