unusable fuel
Fred Klein
PostPosted: Thu Aug 24, 2017 7:56 am    Post subject: unusable fuel Reply with quote
Could someone please tell me what the proper attitude of an XS Mono is when determining the amount of “unusable fuel” on board?
rlborger(at)mac.com
PostPosted: Thu Aug 24, 2017 9:35 am    Post subject: unusable fuel Reply with quote
Fred,
I'd recommend takeoff & climb out attitude as that would be the most critical and when you'd be most likely to uncover the tank outlet.
Bob
davidjoyce(at)doctors.org
PostPosted: Thu Aug 24, 2017 11:31 am    Post subject: unusable fuel Reply with quote
Fred/Bob, That's an entirely reasonable approach since the front end fuel outlets make it the most critical attitude. However it only really applies to those who would contemplate seeing if they can take off with +/- empty tanks. It seems to me much more practicable to go with the cruise attitude, where I guess 99% of fuel starvation happens. So door sill level would be my recommendation.
Regards, David Joyce, GXSDJ
On 2017-08-24 18:34, Robert Borger wrote:
--> Europa-List message posted by: Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)>
Fred,
Bob
On Aug 24, 2017, at 09:55, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
--> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
Could someone please tell me what the proper attitude of an XS Mono is when determining the amount of "unusable fuel" on board?
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.com
.matronics.com/contribution
rlborger(at)mac.com
PostPosted: Thu Aug 24, 2017 12:21 pm    Post subject: unusable fuel Reply with quote
David,
Will that be enough petrol on board if you are on short final at an uncontrolled field and someone pulls out onto the runway and you have to go around?
Best regards,
Robert Borger, President
Geowhiziks & Doodlebugging, Inc.
Certified Petroleum Geophysicist AAPG#101
3705 Lynchburg Dr.
Corinth, TX 76208-5331
(C) 817-992-1117
On Aug 24, 2017, at 14:15, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk) wrote:
Fred,
Bob
ics.com
.com
Fred Klein
PostPosted: Thu Aug 24, 2017 12:39 pm    Post subject: unusable fuel Reply with quote
My reason for raising the question is to select an attitude, after which, I will drain the “usable” fuel and proceed w/ my weighing to determine C of G.
I’m surprised to find well-reasoned yet differing opinions on this.
Fred
On Aug 24, 2017, at 1:21 PM, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
David,
Will that be enough petrol on board if you are on short final at an uncontrolled field and someone pulls out onto the runway and you have to go around?Best regards,
3705 Lynchburg Dr.
(C) 817-992-1117
Fred,
Bob
ics.com
.com
Dave Disney
PostPosted: Thu Aug 24, 2017 12:39 pm    Post subject: Re: unusable fuel Reply with quote
I thought that unusable fuel was measured when determining the empty weight of the aircraft for W&B purposes. Therefore the unusable fuel is measured with the aircraft in the level position when being weighed. Happy to be told I'm wrong (I'm used to it). Very Happy
peterz(at)zutrasoft.com
PostPosted: Thu Aug 24, 2017 1:07 pm    Post subject: unusable fuel Reply with quote
Imho, use the worst case, if pickups are up front then use climb attitude, if extended to rear of tank, then descending attitude Smile
Pete
A239
[quote] On Aug 24, 2017, at 4:39 PM, Fred Klein <fklein(at)orcasonline.com> wrote:
rampil
PostPosted: Thu Aug 24, 2017 2:05 pm    Post subject: Re: unusable fuel Reply with quote
Whether in level attitude or cruise climb, I suspect the difference
in undrainable fuel will be small, based on the square area of the
bottom of the tanks, the fore-aft length of the tanks at the bottom
and, fact that the cg is not far from the tank, and the likely rise
in the front of the tank bottom with such a change in attitude.
Just my opinion.
Ira N224XS
PostPosted: Thu Aug 24, 2017 2:22 pm    Post subject: unusable fuel Reply with quote
Bob, No of course not but I do not plan to ever be on final with anything like an empty tank! It seems to me there are two very different things here - unusable fuel and how anyone sensibly manages his fuel. Unusable fuel is pretty much what it says on the label and this side of the pond its only practical consequence was that the LAA want a figure for it and want it included in the 'ready for service' or empty weight. That apart I am all in favour of gauges telling the true figure of what fuel you have in the tank. Very few would want to work out in flight how much fuel is actually useable or not. We all surely always operate with sensible reserves. In fact a fair number of my aquaintances have never had to use the reserve tank and are rightly proud of themselves. In addition the large majority of my take offs and probably those of my friends are with a full tank - this partly because much of my flying is touring, doing longish stints, but also because I still have a lingering memory of being taught that you should always fill the tank before putting the plane away so as to discourage air cooling in the tank and depositing small amounts of water.
Regards, David
On 2017-08-24 21:21, Robert Borger wrote:
David,
Will that be enough petrol on board if you are on short final at an uncontrolled field and someone pulls out onto the runway and you have to go around? Best regards,
3705 Lynchburg Dr.
(C) 817-992-1117
Fred,
Bob
ics.com
.com
PostPosted: Thu Aug 24, 2017 2:45 pm    Post subject: unusable fuel Reply with quote
PS. I wouldn't expect you to take EASA too seriously, but for what it is worth I have just checked their CS-VLA 959, which holds forth on the subject of unusable fuel, and it says it must be checked for each tank in the most adverse conditions likely to be encountered, so the EU is on your side! David
Regards, David
David,
3705 Lynchburg Dr.
(C) 817-992-1117
Fred,
Bob
ics.com
.com
rlborger(at)mac.com
PostPosted: Thu Aug 24, 2017 3:04 pm    Post subject: unusable fuel Reply with quote
David,
It's the same for the FAA, most adverse condition.
Best regards,
3705 Lynchburg Dr.
(C) 817-992-1117
On Aug 24, 2017, at 17:45, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk) wrote:
On 2017-08-24 23:22, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk) wrote:
Regards, David
David,
Best regards,
3705 Lynchburg Dr.
(C) 817-992-1117
Fred,
Bob
ics.com
.com
Fred Klein
PostPosted: Thu Aug 24, 2017 3:35 pm    Post subject: unusable fuel Reply with quote
Wouldn’t the normal attitude of the mono, sitting on it’s main gear & tail wheel, approximate the “most adverse condition”?
Why not drain the tank w/ acft in that position and be done w/ it?
F.
On Aug 24, 2017, at 4:04 PM, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
David,
It's the same for the FAA, most adverse condition. Best regards,
3705 Lynchburg Dr.
(C) 817-992-1117
Regards, David
David,
3705 Lynchburg Dr.
(C) 817-992-1117
Fred,
Bob
ics.com
.com
AirEupora
PostPosted: Fri Aug 25, 2017 6:36 am    Post subject: Re: unusable fuel Reply with quote
please read FAA AC90-89A http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/D08FA9393154B636862569BA006F6D7F
Section 11, Para. 1 ,e Fuel Flow and Unusable Fuel Check. The whole AC is worth reading and as an EAA Technical Counselor for both Flight & Building I ask everybody to read it before first flight. After a number of accidents and incidents in this area I starting giving a class on first flight to the local EAA chapters. The EAA also has a book that can be downloaded.
I have attached two pictures of my plane undergoing the fuel test and unusable fuel test.
I timed the time it took for the fuel to fill the five gallon bucket then when it quit running cap the line and measure the remaining fuel. If you notice the angle was about 16 degrees or flare attitude. I think mine was about 1.5 gallons remaining.
 Filesize:  453.02 KB
 Viewed:  14528 Time(s)
 Filesize:  454.45 KB
AirEupora
PostPosted: Fri Aug 25, 2017 6:45 am    Post subject: Re: unusable fuel Reply with quote
Should have check the FAA web site before posting! AC-90-89B is current now.
Section 11, Para 1-19, e Fuel Flow (2) for unusable fuel
Hope this helps.
