Standby Alternator Wiring
art(at)zemon.name
PostPosted: Sun Aug 06, 2017 6:45 pm    Post subject: Standby Alternator Wiring Reply with quote
Folks (esp. Bob),
I want to include a B&C standby alternator system bundle in my plane. I am looking at figure Z-12, which calls for a B&C SB-1 controller. Is the SB1B-14 in the current bundle a straight replacement? Does the bundle come with a diagram to update/replace Z-12?
If I understand Z-12 correctly, I need a switch for the standby alternator on/off. I do not see a switch for the main alternator on/off. What would happen if I were to turn on the standby alternator while the main alternator is operating? Would anything be damaged?
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
PostPosted: Mon Aug 07, 2017 2:56 am    Post subject: Re: Standby Alternator Wiring Reply with quote
The main alternator is switched via one half of the master switch.
Nothing will be damaged if both alternators are both turned on, although voltage regulation might not be stable.
Joe Gores
PostPosted: Tue Aug 08, 2017 8:07 am    Post subject: Standby Alternator Wiring Reply with quote
Joe Gores
Running two alternators simultaneously is generally
not a big deal. The alternator with the higher set-point
will 'hog' the load until it's capacity is exceeded.
The bus voltage sags and the alternator with the
lower set point picks up the difference.
Figure Z-12 shows how a second alternator is added
to a single-alternator design. This is done on hundreds
of TC aircraft where the B&C standby alternator is
offered as an option.
The standby alternator is set approx 1.0 volt below
normal bus voltage (0.5v in a 14v system) In flight,
BOTH alternator field switches are ON.
The standby alternator regulator 'sees' what it
perceives is a too-high bus voltage and completely
relaxes . . . s/b alternator field voltage is
reduced to near zero.
If the main alternator shuts down, bus voltage
sags, s/b regulator 'wakes up' and the second
alternator goes to work. The only thing 'magic'
about the s/b alternator is the current sensor
system that annunciates 's/b alternator active'
and assists in load shedding to some value at
or below the alternator's rated output.
But even when the alternators are on line together
and closely adjusted for set point, they're well
behaved.
ashleysc(at)broadstripe.n
PostPosted: Tue Aug 08, 2017 8:39 am    Post subject: Standby Alternator Wiring Reply with quote
Hi Bob;
I find your comments very reassuring. I have a low amperage system (day VFR) and have two identical 20 amp internally regulated permanent magnet alternators (dynamos) installed. I have them set up to run independently or in parallel via toggle switches on the panel. I was expecting to try it both ways to see what happens. Still will, but now somewhat more optimistic. Keep up "The Good Work."
Cheers! Stu.
Sent: Tuesday, August 8, 2017 9:06:34 AM
Subject: Re: Re: Standby Alternator Wiring
Joe Gores
behaved.
art(at)zemon.name
PostPosted: Tue Aug 08, 2017 4:59 pm    Post subject: Standby Alternator Wiring Reply with quote
Thanks for explaining. I was going to build Z-12 for my plane but I did not understand why it worked without your explanation.
    -- Art Z.
On Tue, Aug 8, 2017 at 11:06 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
   behaved.
