whodja
Joined: 27 Jan 2014 Posts: 50 Location: Apex NC (near Raleigh)
Posted: Wed Jul 12, 2017 7:20 am Post subject: Van's FWF kit |
I've read numerous posts regarding different options when installing the engine. Does anyone know of a list of recommendations for items to delete from the Van's FWF kit. I'm installing the IO-540 from Lycoming with 1 slick and 1 pmag.
tsts4
Posted: Wed Jul 12, 2017 1:58 pm Post subject: Re: Van's FWF kit |
Its been awhile but IIRC I deleted most of the hoses (which I replaced with ones from Tom at TS Flightlnes), the alternator, and the oil cooler mount/bracket (which I had bought earlier so I could install it during firewall construction).
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
Lenny Iszak
Posted: Wed Jul 12, 2017 7:11 pm Post subject: Re: Van's FWF kit |
I'd delete the Pmag and move on to something that's actually available.
It was ready to ship within the next two weeks at least 7 years ago.
If you are going with the stock Lycoming, Van's cowling, Hartzell prop then the fwf kit is adequate. I upgraded all the hoses to integral firesleeve from Stratoflex. If I were to do it again I'd get the fuel hoses with the red external firesleeve on it. It may keep the fuel inside the hose a bit cooler.
Also, delete the hose that's connecting the fuel injection servo and the spider and get two shorter ones to connect the fuel flow sender in between there.
Lenny
| whodja wrote: | | I've read numerous posts regarding different options when installing the engine. Does anyone know of a list of recommendations for items to delete from the Van's FWF kit. I'm installing the IO-540 from Lycoming with 1 slick and 1 pmag. |
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Posted: Fri Jul 14, 2017 10:34 am Post subject: Van's FWF kit |
It's been awhile but assuming that the kit includes the black baffle
material, I'd delete and replace with a sheet of silicon material. Easy
to work with, virtually like new after 900 hours, the orange/red looks
good too.
On 7/12/2017 11:20 AM, whodja wrote:
