kearney
Posted: Sat Jul 08, 2017 5:51 pm Post subject: Question for the IO-540 Engine Mavens |
Hi
Today I got a line on an IO-540 AE1A5 engine that was in a helicopter. It has 500 TSNew. It has had a the helicopter equivalent of a prop strike and so needs to be inspected etc.
Can anyone tell me if it possible to use this engine as a core for use in a -10. I would plan on having the engine inspected / overhauled / converted for use on my project if it makes economic sense.
Inquiring minds need to know...
Les
C-GCWZ flying
C-GROK some assembly required
digidocs
Posted: Sat Jul 08, 2017 6:44 pm Post subject: Question for the IO-540 Engine Mavens |
Hi Les,
I don't thing this engine will be a good fit unfortunately. The IO-540 TCDS describes it as follows:
-AE1A5 - Similar to O-540-F1B5 with IO-540-K angle valve cylinders, pistons,
piston squirts and fuel injection and induction system.
It will have angle valve cylinders which are too wide for the RV-10 cowl. It also weighs 416 lbs vs. the 379lbs of the stock D4A5. I'm not sure, but it's also likely that the sump and/or case geometry may cause issues.
David
On Sat, Jul 8, 2017 at 8:51 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
| Quote: | --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Les
C-GCWZ flying
http://forums.matronics.com/viewtopic.php?p=470805#470805
