rv10free2fly(at)yahoo.com Guest
Posted: Thu Jul 06, 2017 3:13 am Post subject: Fuel filter/gascolator screen advice |
Many thanks Les.
Warm regards
Patrick
| Quote: | On 12 Jun 2017, at 06:34, kearney <kearney(at)shaw.ca> wrote:
Hi
FWIW I put my fuel filters n the wing roots. I did at one point have them under the seats. Under the seats is just a little less inconvenient than the tunnel. Even though I put an access panel in the tunnel, I wanted to be able to inspect the filters quickly and easily. All I need do now is to remove the top root cover and the filters are out in a couple of minutes.
I also wanted to minimize connections inside the cockpit and near the exhaust.
I used Earls Performance fuel filters which have worked out quite well. The filters screens are easily removed and cleaned.
Cheers
Les
C-GCWZ flying
C-GROK some assembly required
http://forums.matronics.com/viewtopic.php?p=469979#469979
