tsts4
Posted: Sun Jun 25, 2017 12:17 pm Post subject: AOG in Florida--Need an assist |
Folks the Display Unit for my Vertical Power VP-200 has died, at least partially. If I cycle the power I can see the very very faint VP-200 startup logo and the startup systems check annunciations (they are so faint as to be illegible but I know what they are) but then a blank screen with the Soft Key label boxes barely visible but the labels themselves are illegible. The DU seems to still be controlling power pins and the control unit and the switch panel all seem to be functioning fine although it's impossible know 100% for sure without a full-up display.
Does anyone have a Display unit I could borrow/rent/buy, at least to get me home? I'll be here at Pompano Beach until July 1st and across the state over in Fort Myers until July 9th (so I'd like to get it fixed by then) I'll pay for overnight shipping. Email me at tsts4us AT gmail dot com or text/call me 703-595-5453.
Thanks!
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
Lenny Iszak
Posted: Sun Jun 25, 2017 1:23 pm Post subject: AOG in Florida--Need an assist |
Hey Todd,
I don't have a VP-200 screen but I live close by at 64FA. I'll be home on the 28th or so. I have a bunch of tools, if you need anything let me know.
Sounds like the backlight in your screen is out. If you can source the lcd screen or even just the backlight I can repair it for you.
Lenny
Thanks!
Todd Stovall
aka Auburntsts on EAA, AOPA, and VAF
http://forums.matronics.com/viewtopic.php?p=470466#470466
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
tsts4
Posted: Sun Jun 25, 2017 1:41 pm Post subject: Re: AOG in Florida--Need an assist |
Thanks Lenny -- if I can't a new DU or backlight I might need some help with some tools and 14-20 ga wire as I'm already working a worst case back-up plan to bypass the CU and get power to all of the necessary systems required to safely get home.
tsts4
Posted: Sun Jun 25, 2017 3:03 pm Post subject: Re: AOG in Florida--Need an assist |
Lenny,
If I open the DU's case, is the backlight or screen part numbers something I could identify without an electronic's background?
Lenny Iszak
Posted: Sun Jun 25, 2017 3:27 pm Post subject: AOG in Florida--Need an assist |
The backlight is usually inside the lcd frame, on the side. Try to get the part number from the LCD then you can see the size of the backlight, and order an aftermarket replacement.
There's a remote possibility of the inverter being bad, which is the driver of the backlight. Usually the backlight burns out though.
Lenny
| Quote: | On Jun 25, 2017, at 7:03 PM, tsts4 <tsts4us(at)gmail.com> wrote:
Lenny,
Todd Stovall
http://forums.matronics.com/viewtopic.php?p=470474#470474
Palm City, FL
tsts4
