Kx 170 b radio, ki211c indicator no power to ki 211c pin a
dave(at)evergreengeo.com
PostPosted: Sat Jun 24, 2017 1:56 pm    Post subject: Kx 170 b radio, ki211c indicator no power to ki 211c pin a Reply with quote
Hi guys, been away from flying a while, and airplane mode and N77FE is a bit pissed off at beong ignored.
Cant get my cdi to power up.
I tried both my kx 170b and michel mx 170 in the tray.    I pulled the cdi and the connector was loose, so fixed that.  Probed for power.   Pin c on ki 211 is supposed to be 13.75 v input, no power there w nav radio on.   I do get gs energize power at pin p when tuned to gs freq.
 Pin 26 is power out from tray, probed from there to connector end of cdi connector pin c and wire is connected. Continuity is solid.
Does the tray connector jumper power to the cdi, or does the radio switch it?  Im kinda baffled.
Page 2-13 shows what i think I have.
Thanks, Dave Leonard Super viking N77FE
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.aeroelectric.com/Installation_Data/Bendix-King/KX175B_IM.pdf&ved=0ahUKEwiSucHOuNfUAhWp64MKHfcCBQ0QFggdMAA&usg=AFQjCNEMWUD78gQVdc-xgRjp70uLbwJ1bA
