Backup ignition failure
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
tshankland(at)sbcglobal.n
PostPosted: Sun Sep 17, 2017 11:52 am    Post subject: Backup ignition failure Reply with quote
Pavel,
The ss461 Hall effects device is a switch which responds to the polarity of
the magnetic field. One pole of a magnet will turn it off and the other will
turn it on. The flywheel had two magnet in it one reversed from the other.
It is important that the ss461 be properly oriented in the sensor so that
the coil will fire on the proper magnet. The faceted side of the device with
the number should face out.
Tim Shankland
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
