Posted: Thu Jun 08, 2017 11:06 am Post subject: Floor covering |
Guys
Regarding the 4 seats floor panels, how did you cover it?
With some kind of glues carpet? Or just removable mats?
And by the way, how about the baggage compartment? Did you glue some carpet? Is there any light, thin and fire resistant carpet?
Can you please share your solutions?
Carlos
Posted: Thu Jun 08, 2017 11:20 am Post subject: Floor covering |
Not flying yet, but I plan on removable floor mats. I've had fixed floor mats in many planes and was frustrated by trying to get the shop-vac and it's hose and me to reach the floor mats. So much easier to remove the mats and vacuum/wash, and a small hand vacuum will get all the debris along the edge of the now-missing mat. I'll try velcro to anchor the mats down and if that fails under use I'll use snaps as a last resort.
Linn
On 6/8/2017 3:06 PM, Carlos Trigo wrote:
| Quote: | <![endif]--> <![endif]-->
Guys
Carlos
Checked by AVG - www.avg.com
Date: 06/08/17 |
jdriggs49(at)MSN.COM Guest
Posted: Thu Jun 08, 2017 11:41 am Post subject: Floor covering |
The shop I used provided Velcro to stick it to the floor. I never installed it as it fits pretty well as is and doesn't slide around.
On Jun 8, 2017, at 12:25 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
| Quote: | Not flying yet, but I plan on removable floor mats. I've had fixed floor mats in many planes and was frustrated by trying to get the shop-vac and it's hose and me to reach the floor mats. So much easier to remove the mats and vacuum/wash, and a small hand vacuum will get all the debris along the edge of the now-missing mat. I'll try velcro to anchor the mats down and if that fails under use I'll use snaps as a last resort.
Linn
Guys
Carlos
Date: 06/08/17 |
rene(at)felker.com Guest
Posted: Thu Jun 08, 2017 1:26 pm Post subject: Floor covering |
I got all my interior form Abbey at Flight Line. You can order what you want from her and it is ready to go. If you need more info I can dig it up when I get home.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Thursday, June 08, 2017 1:06 PM
Subject: Floor covering
Guys
Carlos
rv10flyer(at)live.com Guest
Posted: Thu Jun 08, 2017 1:37 pm Post subject: Floor covering |
Carlos;
I have removable rug. In my case I had surplus so I cut the area to fit exactly into the four sections. The two in the back are easy squares, the two in the front hace the rug going around the aluminum in the corner- it is that “slip in” that keeps the rug straight and because it fits exactly, it hasn’t moved in 6 years, well except to take out and clean.
The baggage rug has 4 tie downs I installed and it sits over (around) them so the four corners are held in place by the tie downs.
Next time I am at hangar, I’ll take some pictures for you. Really easy and inexpensive. I did get an upholstery shop to stitch a border around the rugs.
Pascal
Sent: Thursday, June 08, 2017 12:06 PM
Guys
Carlos
aerosport1
Posted: Fri Jun 09, 2017 4:10 am Post subject: Floor covering |
Carlos
Aerosport products offers a complete set of carpet for the
RV-10
Geoff
Sent from my iPhoneGeoff Combs
Aerosport Modeling & Design
On Jun 8, 2017, at 3:06 PM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Guys
Carlos
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
