dlm34077(at)gmail.com Guest
Posted: Tue May 23, 2017 6:13 am Post subject: cowl heat protection |
I used a silicon backed layer of fiberglass mat; after 1000 hr. it was OK; no apparent delamination. From last June to April 2017, I found three areas of delamination and had to replace multi layers both sides of the Nomex core. Unfortunately last June, I let an FBO do some work and unknown to me, the baffling was not correctly reinstalled and sealed; it is unknown whether this contributed to the delamination. The cowl has been fixed except for the new heat protection. What are other builders using? what are your results? My plan now is to use the reflective aluminum adhesive back material for the areas near (less than 3") the exhaust system. Selected areas will also have Fiberfrax beneath the reflective foil. Per the heat document from Vans, I will not be wrapping selected exhaust system areas, although an IA friend says that turbine exhaust systems are routinely wrapped. Any suggestions other than NEVER LET ANYONE ELSE TOUCH.
jump2(at)sbcglobal.net Guest
Posted: Tue May 23, 2017 1:34 pm Post subject: cowl heat protection |
I have reflective aluminum on inside cowl, no problems just shy of 1000 hrs. I did paint inside of cowling so it had a good base to adhere to.
Patrick Thyssen
bill.peyton
Posted: Wed May 24, 2017 4:36 am Post subject: Re: cowl heat protection |
I used the adhesive reflective stuff you can purchase from ACS. 600 hours and no issues. Photo below
105.34 KB |
7300 Time(s) |
_________________ Bill
WA0SYV
Aviation Partners, LLC |
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Wed May 24, 2017 4:45 am Post subject: Re: cowl heat protection |
I did the same as Patrick and it works well after 550 hours. The coverage needs to be fairly extensive. I also have a bolt-on heat shield where the exhaust pipe passes close to the cowl.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
schmoboy
Posted: Wed May 24, 2017 4:59 am Post subject: cowl heat protection |
In addition to the reflective foil I painted the inside of the cowl with
a few coats of white high-temp grill paint available at your local home
store. I don't have a 1000 hours of testing, but so far no issues.
-Sean #40303
| Quote: | dlm <mailto:dlm34077(at)gmail.com>
May 23, 2017 at 9:13 AM
