| mark.bitterlich(at)navy.m Guest
				|  Posted: Sun May 14, 2017 11:26 am    Post subject: [Non-DoD Source] Re: Generator failure/ loss of  electrical |   |
				| Hans O,  I really do NOT want to sell my 50.  It has been a true love affair, but I am moving on and it might turn into a simple matter of money....    Yes, you're correct ... when the 50 goes, I don't think I will hang out on the Yak List anymore.  There are a LOT of nice folks there, but too many of the other kind.  You might have noticed that I do not comment on there very much anymore.
 Thanks for writing, and I hope all turns out well with your radio issue!
 Mark
 ________________________________________
 From: owner-yak-list-server(at)matronics.com [owner-yak-list-server(at)matronics.com] on behalf of Hans Oortman [pa3arw(at)ziggo.nl]
 Sent: Sunday, May 14, 2017 4:34 AM
 To: yak-list(at)matronics.com
 Subject: [Non-DoD Source] Re: Generator failure/ loss of electrical power
 Good story Mark and very true!
 BTW: the batteries in my Yak52 were put in there in 2002 when I picked her
 up in Lithuania. Until now they have never let me down and have not been
 replaced yet. All other things original Russian with the good old dc
 generator.
 Sad to read y're gone probably sell yr Yak50....so w're possibly gone miss
 you here on the net??
 Hans O.
 PH-YAK
 Op 14-05-17 01:08, Bitterlich, Mark G CIV NAVAIR, WD
 <mark.bitterlich(at)navy.mil> schreef:
  	  | Quote: |  	  | <mark.bitterlich(at)navy.mil>
 There are a couple of folks that have already commented on the proper setting
 for the generator voltage, and I want everyone reading this to know that I
 have high regard and respect for everyone that commented.  They have also said
 some very nice things about me, for which I am gratified.  This is going to be
 a long discussion, so be fore-warned.  If you donıt like listening to Mark
 talk, then just stop right here and discard the message.  OK?  That should
 stop some of the flak from the peanut gallery.  Be aware that I rarely write
 up explanations like this anymore, so donıt worry this is an exception to the
 rule.
 So with that said, there is a part of me that does not even want to discuss
 this, but what the heck, I hope I donıt lose any friends.
 First of all, EVERYBODY is correct in what they said regarding this topic.  No
 one is wrong.  That is kind of a unique situation really, but factually it is
 the truth.
 First of all, there was a reference to the Yak manuals, and what they say the
 proper output voltage of the generator should be set to.  Yes, they all
 specify over 28 volts DC, and that is for a number of reasons.  All of the
 equipment in these aircraft, namely engine instruments, voltage inverters for
 gyroıs, pitot heat, radios, and on and on  ALL of these things were designed
 to operate at the specified voltage of 28 volts, or 28.5 VDC.  The original
 battery in these aircraft was typically a Nickel Cadmium design, and the
 charging voltage for this battery also met the design generator output voltage
 specified in the publications.
 But then these aircraft came to the United States, and people started
 immediately pulling out the original NiCad battery (which was pretty much
 impossible to maintain) and started replacing it with two 12 volt gel cell
 batteries.  Some of the really serious aerobatic types installed two very
 light weight and minimum capacity batteries, and in my opinion this was a
 serious mistake.  These batteries combined with the B&C PMG Alternator (the 10
 amp version) could combine to cause serious damage to avionics components, and
 Iıve watched it happen a few times now, regardless of the warnings I have
 given to a few owners.  Most of them finally learned, use different batteries
 (yes, Gel Cell too), but larger, and with a better alternator like the B&C
 SK-35, which is a wonderful design with the LS1A regulator.
 Getting back to gel cell batteries.  If you read the fine print that usually
 comes with these batteries, you will see that they have a MAXIMUM RECOMMENDED
 CHARGING CURRENT!  Charging current is typically controlled by varying
 charging voltage on the fly.  One problem  the YAK and CJ aircraft do not
 have an inherent system for controlling charging current, voltage yes, current
 no.
 So here we have a conundrum.  We are installing gel cell batteries that
 typically have smaller inherent capacity than what was originally installed.
 This a very important point.  Further, they are a different TYPE of battery
 than was originally installed, and they are supposed to be charged at a lower
 CURRENT than what was originally assumed.
 So if you leave your voltage set for 28.5 VDC or whatever the Russian manual
 says, then it is going to result in a little bit too high of a charging
 current for the gel cell batteries as recommended by the manufactuer.  This
 will then cause the batteries to gas, and once that happens battery capacity
 diminishes.  Note:  Causing a gel cell to gas is bad business.  But then to be
 honest, all batteries die eventually.  You can extend their life by using
 fancy chargers like Battery Minders (I like these a lot by the way), which
 will shoot a short blast of HF energy around 3 MHz into the battery to help
 recombine sulfates back into acid and off the plates but in the end, they all
 go bad.
 The important thing is to know that you need to check them.   Five years is
 indeed a long time for battery life in these aircraft, but it is feasible if
 you have spent a lot of effort watching charging current and using chargers
 like the Battery Minder brand.
 What is important to understand is the way generators work.  A generator has a
 plus and minus connection that outputs voltage correct?  Yes it does.  But
 when the generator is not turning, the PLUS connection on it is essentially a
 dead short to ground.  That is a bad bad thing to have your battery connected
 to.  If you connect a good battery to a dead short to ground, there is going
 to be a lot of current flowing, and fuses will blow, relays will burn out and
 wires can melt.  It is a very very bad thing.
 As a generator starts spinning slower and slower . Like when your M-14P
 engine is coming back to idle, it is not spinning fast enough to deliver a
 voltage higher than what is in your battery.  At that point, current starts
 flowing BACKWARDS or IN REVERSE to your generator FROM the battery.  The
 slower the generator spins, the less voltage it will then produce and the more
 current will flow back into the generator from the battery.
 The DMR-200 Combined Relay device is put in there to control this situation.
 Remember my previous post about the MAIN CONTACTOR RELAY.  This relay is what
 connects the generator to the main electrical bus of the aircraft, and thus
 the battery as well.  When current starts flowing backwards into the generator
 from the battery, there is a special device called THE REVERSE CURRENT RELAY
 that senses this.  Once that current gets high enough, it will cause the MAIN
 CONTACTOR RELAY TO OPEN (!!!!)  thus disconnecting the generator from the rest
 of the aircraft.  TA-DA!  Problem solved!  And yes, that is when the Generator
 light comes on!
 But letıs say you have some weak half assed batteries, that you are trying to
 get the last bit of life out of, because you are too cheap to buy new ones.
 Sorry, sometimes I get carried away, but it is the truth.  People have done
 this all the time, and I have watched them do it.
 Now when your generator slows down, you start getting reverse current, but the
 battery is so darn weak, it cannot supply ENOUGH current to cause the reverse
 current relay to sense it.  Now you start to have a voltage droop in the
 aircraft.  Voltage goes lower and lower as the weak batteries discharge more
 and more.  So now instead of a quick disconnect of the generator, you instead
 get a lower and lower battery supply voltage to EVERYTHING in the aircraft
 that is designed to run off 28 volts.  Radios, Transponders, GPSıs, you name
 it.  They are now all being subjected to a lower voltage than they were
 designed to operate with.  Sometimes they have had enough and fail.  Whoıs
 fault is that?  Yep yours, the aircraft owner.
 So batteries need to be checked.  The easiest way is to put a fairly good load
 on the batteries and verify that their voltage does not drop too low.  If you
 are not up for that, then a good idea is to just replace them every few years
 and be done with it.
 So I took the time to write this.  I hope it was useful to you.  Feel free to
 write me directly if you disagree, or have a technical input that you feel I
 missed.  I very well could have.  This whole thing is like a string of
 Dominoes going down, but you need to keep it in mind.
 So yes, you can lower the charging voltage to try and limit charging current
 to gel cells, but this is also a two edged sword.  My input is to leave it
 where the manual says it should be set to, use a Battery Minder charger with a
 sulfate blaster at 3.4 MHz, and just bite the bullet and replace those
 batteries on a regular basis, and donıt use itsy-bitsy batteries dumb move
 Kemo Sabi.
 Mark Bitterlich
 Whoıs YAK-50 is probably going up for sale.
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
