JabiruEngine-List Digest: 0 Msgs - 04/12/17
tech(at)sonexaircraft.com
PostPosted: Tue Apr 18, 2017 9:53 am    Post subject: JabiruEngine-List Digest: 0 Msgs - 04/12/17 Reply with quote
Sonex Tech Support will be limited from April 13 through April 18th.
Beginning April 18th, responses to technical emails will be prioritized
until all emails have been answered.
If your inquiry is not related to the active construction of our products,
please contact one of the departments listed below.
Sonex Aircraft Tech Support
Sonex Aircraft LLC
511 Aviation Road
Oshkosh, WI 54902
Tech Line: (920) 230-TECH (8324)
Mon, Wed. and Fri. 10 AM to 12 AM and 2PM to 4PM CT
Orders and General Info:
Ph.920-231-8297
Fax (920) 426-8333
http://www.sonexaircraft.com
Please use the following e-mail addresses to Contact Sonex Aircraft:
Sales Info: sales(at)sonexaircraft.com
Orders: orders(at)sonexaircraft.com
Accounting: accounting(at)sonexaircraft.com
Tech Support: tech(at)sonexaircraft.com
__________
Sonex Aircraft, LLC Technical Support Disclaimer: Any tech support provided
in this e-mail is supplied for your consideration/evaluation only. Only
airframes built strictly to the plans have been thoroughly engineered and
tested by Sonex Aircraft LLC. Any deviations from the Sonex, Waiex, or Xenos
plans are accomplished at the builder's own risk.
This email message and all attachments may contain legally privileged and
confidential information intended solely for the use of the addressee. If
you are not the intended recipient, stop reading this message and delete it
from your system. Any unauthorized reading, distribution, copying or other
use of this message or its attachments is strictly prohibited.
