kearney
Posted: Fri Apr 07, 2017 6:06 pm Post subject: Antenna Followup |
Hi
I have another antenna follow up question. If I install a Company bent whip antenna, is there any reason I can't use it for two comm radios through the use of a splitter?
Cheers
Les
Kellym
Posted: Fri Apr 07, 2017 6:13 pm Post subject: Antenna Followup |
Yes. There is no reliable way to isolate the transmitter on one com from
the receiver on the other com, creating a likely hazard of frying the
receiver on one while transmitting on the other.
Just install 2 bent whip antennas, installed as far apart as you can
conveniently get them.
On 4/7/2017 7:06 PM, kearney wrote:
KCHD |
kearney
Posted: Fri Apr 07, 2017 6:54 pm Post subject: Re: Antenna Followup |
Hmmm
That sounds way too logical. But I guess two bent whip Comants is the way to go.
Thanks Kelly
Cheers
Les
