Condition inspection
Kellym
PostPosted: Mon Mar 27, 2017 8:03 am    Post subject: Condition inspection Reply with quote
Tim,
I think we are in violent agreement over the fuel.
It hardly seems like a year has gone by, but I need to do the condition
inspection.
Just wondering if you have developed or collected a checklist that is
particularly relevant to the RV-10. I'm very familiar with the Appendix
D checklist, but it is way too generic.
On 3/27/2017 7:43 AM, Tim Olson wrote:
As long as you understand that nearly the entire reason that
the fuel has a different "weight" per gallon is that the
actual QUANTITY of fuel molecules in that gallon is less
as it gets warmer, then you're right on. It's a VOLUME
issue, not a weight issue. If you took hot fuel
of a given weight, and cold fuel of a given weight, and
brought them to the same temperature, they would still
weigh the same but have different VOLUMES.
Kelly McMullen
KCHD
Tim Olson
PostPosted: Mon Mar 27, 2017 10:05 am    Post subject: Condition inspection Reply with quote
Hey Kelly,
The time is really flying by. Just this weekend I was working
thru mine on both airplanes. There are a few things I'd like to
revise on this, but this is the one I've used in the past.
http://www.myrv10.com/N104CD/maintenance/20070225/index.html
I should probably add in the various areas that were covered by
SB's over the past years. I just did the aileron hinge bracket
check on both planes this year and of course found no cracks.
I find the RV's really nice and easy to inspect at least from
a flight controls perspective.
Tim
On 03/27/2017 11:01 AM, Kelly McMullen wrote:
Tim,
inspection.
