road transport question
ceengland7(at)gmail.com
PostPosted: Sat Mar 18, 2017 8:01 am    Post subject: road transport question Reply with quote
Well, after mostly lurking here for many years, and somewhat passively searching for a Kolb for most of that time, I've found a formerly flying project a/c. It's a complete 582 powered Twinstar, but it's completely disassembled.
My question for those who have moved projects is this: How much space is needed for transport? The wings & tail are still covered, so they're complete but disassembled. The cage is off the tailboom (already sandblasted & repainted). Could this project be transported using, for instance, a mid size car towing a small 5' x 8' utility trailer (typically used to haul golf carts/ UTV's)? I'd obviously need to build a rack for the wings/tail/fuselage tube. I know weight shouldn't be an issue, but size concerns me.
What about a standard pickup truck, with a rack on it (no trailer)?
williamtsullivan(at)att.n
PostPosted: Sat Mar 18, 2017 8:38 am    Post subject: road transport question Reply with quote
Ellery Batchelder had a couple of photos showing one on a standard pickup truck, with a rack. You could probably also use a U-Haul car trailer.
Does the plane have an N number? if not, it might be a problem.
Bill Sullivan
Windsor Locks, Ct.
On Sat, 3/18/17, Charlie England <ceengland7(at)gmail.com> wrote:
Subject: road transport question
on it (no trailer)?
PostPosted: Sat Mar 18, 2017 10:10 am    Post subject: road transport question Reply with quote
Bill Sullivan
Windsor Locks, Ct.
It is N numbered; belongs to a friend, so I'm fairly confident on the
paperwork front.
I've got another trailer that was custom built to haul a Thorp T-18, but
it hasn't been on the road in at least 20 years so I don't really want
to go there... I'm trying for either something light enough to pull
behind a 4cyl car, or loaded in/on a rental pickup. Hauling something as
heavy as a car hauler trailer gets gas prohibitive really quick; the
plane is ~600 miles away.
If it's been done on a pickup, my 5x8 trailer should work fine.
Many thanks,
Herbgh(at)nctc.com
PostPosted: Sat Mar 18, 2017 10:21 am    Post subject: road transport question Reply with quote
Find yourself a decent boat trailer...reinstall the wings and support
them at the rear...three or four feet in front of the tail... lay a 2x12
toward the front to hold the main gear...same at the rear with a pedstal
that is well cushioned to hold the boom tube...roll/lift it on and fold
the wings last...I use good strength , winching type straps to hold the
wheels and 2/12's in place..Herb
> <williamtsullivan(at)att.net>
> trailer.
> Bill
> Sullivan
> Windsor Locks, Ct.
paperwork front.
but it hasn't been on the road in at least 20 years so I don't really
want to go there... I'm trying for either something light enough to
pull behind a 4cyl car, or loaded in/on a rental pickup. Hauling
something as heavy as a car hauler trailer gets gas prohibitive really
quick; the plane is ~600 miles away.
Many thanks,
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny."
Aristotle
lcottrell
PostPosted: Sat Mar 18, 2017 10:38 am    Post subject: road transport question Reply with quote
Charlie I pulled a 24 foot home made trailer with a firestar ii from Lincoln Neb with a Subaru legacy to Klamath Falls Oregon. The key is - can you keep the wings from being damaged. The cage and the rest should be no problem. I hauled mine with it only folded.Larry
On Sat, Mar 18, 2017 at 12:11 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> Kolb-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
--> Kolb-List message posted by: william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)>
                                                            Bill Sullivan
                                                            Windsor Locks, Ct.
It is N numbered; belongs to a friend, so I'm fairly confident on the paperwork front.
I've got another trailer that was custom built to haul a Thorp T-18, but it hasn't been on the road in at least 20 years so I don't really want to go there... I'm trying for either something light enough to pull behind a 4cyl car, or loaded in/on a rental pickup. Hauling something as heavy as a car hauler trailer gets gas prohibitive really quick; the plane is ~600 miles away.
Many thanks,
The older I get, the less tolerant I am of those who are intolerant of others.
gdhelton(at)gmail.com
PostPosted: Sat Mar 18, 2017 11:19 am    Post subject: road transport question Reply with quote
Having owned, built and flown a twinstar. I'd say that I'd try find something fully enclosed. That being said, if you could put the cage and stuff like the engine, etc. in the pickup bed? The wings could be transported in good wing rack, wing facing forward towards the truck. Should really pad and cover well. If damage a wing it will be really bad news. Attached is a picture of my shop wing rack.
Have a great day!
On Mar 18, 2017, at 12:01 PM, Charlie England <ceengland7(at)gmail.com> wrote:
 Filesize:  34.37 KB
 Viewed:  12176 Time(s)
PostPosted: Sat Mar 18, 2017 12:49 pm    Post subject: road transport question Reply with quote
Sounds good, if it was an assembled a/c. It's not. As I said, the
individual components are complete, but the cage is bare; not mounted to
the big tube, and nothing is attached to anything else. Right now it's
just a big quickbuild kit. Smile
If the wings are around 15', it would seem that it's doable on the 8'
trailer if I use a bit of overhang on both ends.
On 3/18/2017 1:20 PM, Herb wrote:
support them at the rear...three or four feet in front of the tail...
lay a 2x12 toward the front to hold the main gear...same at the rear
with a pedstal that is well cushioned to hold the boom
tube...roll/lift it on and fold the wings last...I use good strength ,
winching type straps to hold the wheels and 2/12's in place..Herb
>> U-Haul car trailer.
>> Bill Sullivan
>> Windsor Locks, Ct.
> paperwork front.
> Many thanks,
> Charlie
PostPosted: Sat Mar 18, 2017 12:56 pm    Post subject: road transport question Reply with quote
Thanks for the pic; looks just like what we RV-x guys use for our wings. Are you saying that the rack pictured would be adequate for road transport of the wings? Are the leading edges strong enough to support the wing weight on a couple of 8-10" wide carpet strips? If so, that would simplify my task considerably. The rest of the stuff I can deal with, but the wings concern me. I was envisioning something more like a couple of heavily padded shelves as big as the wing(s).
Have a great day!
On Mar 18, 2017, at 12:01 PM, Charlie England <ceengland7(at)gmail.com> (ceengland7(at)gmail.com) wrote:
zeprep251(at)aol.com
PostPosted: Sat Mar 18, 2017 1:02 pm    Post subject: road transport question Reply with quote
We use 4" foam rubber
On Mar 18, 2017, at 4:56 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Have a great day!
PostPosted: Sat Mar 18, 2017 1:10 pm    Post subject: road transport question Reply with quote
I would actually prefer either adding a couple more straps inboard to this design. I would use some dense foam where the leading edges rest. I'd use some light straps to hold the wings in place. Wings need to be covered to keep air blast from go in between.
Have a great day!
George ( Maddog )
Have a great day!
west1m
PostPosted: Sat Mar 18, 2017 1:34 pm    Post subject: Re: road transport question Reply with quote
My money is on the boat trailer. I brought home a Quicksilver from Wichita (to Saint Paul, MN) using a boat trailer and later brought home my Firefly on a boat trailer from New York. I think it cost me more in tolls than gas!
Kolb Trailer
 Filesize:  131.5 KB
 Viewed:  12164 Time(s)
Trailering a Quicksilver
 Filesize:  183.78 KB
West1m
Hastings, MN
PostPosted: Sat Mar 18, 2017 2:19 pm    Post subject: road transport question Reply with quote
My T-18 trailer actually looks a lot like that, except the axle is farther aft to support the weight of the T18's Lyc engine.
Thanks for all the suggestions; I'll likely head down there with  a stack of 2x4's, several sheets of plywood, and a trunk full of pads & foam sheets.
On Sat, Mar 18, 2017 at 4:34 PM, west1m <west1m(at)hotmail.com (west1m(at)hotmail.com)> wrote:
--> Kolb-List message posted by: "west1m" <west1m(at)hotmail.com (west1m(at)hotmail.com)>
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=467452#467452
http://forums.matronics.com//files/trailer2_597.jpg
http://forums.matronics.com//files/trailer1_128.jpg
Mark K
PostPosted: Sun Mar 19, 2017 8:03 am    Post subject: Re: road transport question Reply with quote
I was lucky enough that my brother-in-law had an enclosed trailer, about 16ft long that we used to go pick up my Twinstar MK II in Michigan. We supported the wings from the ceiling and strapped the cage, boom and tail feathers to the floor. The wings and tail feathers were covered and sealed and traveled very well. The wings just fit between the front wall and the big laydown rear door.
 Filesize:  1.05 MB
 Viewed:  12135 Time(s)
Mark
Twinstar MKII
Great Bend, PA
