flysrv10(at)gmail.com Guest
Posted: Fri Feb 24, 2017 8:08 am Post subject: Break model. |
Guys,
Need help. Break failure at run up area. Need the wheel and caliper model to get o ring and pads. Thanks a bunch.
Tim Olson
Posted: Fri Feb 24, 2017 8:29 am Post subject: Break model. |
Hi Rob,
If you are using stock Cleveland, then this is it:
Brake Assembly 30-59E
Brake Pads 66-112
Rivets 105-2
Disc part number RA164-07500 For Rapco version
Wheel Assembly is 40-59A
For caliper o-rings if you can go Viton, do it:
The Viton o-rings are M83248/1-224 V-75
Hope that helps you out!
On 2/24/2017 10:07 AM, Rob Kermanj wrote:
Guys,
bdgillespie215(at)gmail.c Guest
Posted: Fri Feb 24, 2017 8:30 am Post subject: Break model. |
Not sure if this is what you are looking for.... had this noted in my POH.
Main Brakes: 30-59E assy Torque 75-80 in-lb dry Linings: Cleveland 66-112 Rivets: 105-2 Disc: 164-07500 Fluid: Aeroshell Mil-H-5606G
Sent from my iPad
| Quote: | On Feb 24, 2017, at 11:07 AM, Rob Kermanj <flysrv10(at)gmail.com> wrote:
Guys,
Posted: Fri Feb 24, 2017 8:52 am Post subject: Break model. |
Thank you! On my way to ABQ to pick up the parts.
| Quote: | On Feb 24, 2017, at 9:27 AM, Home <bdgillespie215(at)gmail.com> wrote:
Sent from my iPad
> Guys,
> Sent from my iPhone
gengrumpy
Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
Posted: Fri Feb 24, 2017 9:01 am Post subject: Break model. |
Hope this helps!
grumpy Cleveland, Wheel 40-59A; Disc 164-07500 Grease seals: 153-00300 outer; 153-00400 inner. Snap ring 155-00100. Lining 066-11200. Rivet 105-00200. Dust Sheld 157-00900; Wheel bolts AN5-34A; MS21044-N5 nuts Timken Bearing LM274949-2-629, cotter pin AN 380-3-8. Torque halves 150in lb dry | Quote: | On Feb 24, 2017, at 10:52 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
--> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> Thank you! On my way to ABQ to pick up the parts. Sent from my iPhone | Quote: | On Feb 24, 2017, at 9:27 AM, Home <bdgillespie215(at)gmail.com (bdgillespie215(at)gmail.com)> wrote:--> RV10-List message posted by: Home <bdgillespie215(at)gmail.com (bdgillespie215(at)gmail.com)>Not sure if this is what you are looking for.... had this noted in my POH.Main Brakes: 30-59E assy Torque 75-80 in-lb dry Linings: Cleveland 66-112 Rivets: 105-2 Disc: 164-07500 Fluid: Aeroshell Mil-H-5606GSent from my iPad | Quote: | | On Feb 24, 2017, at 11:07 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:--> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)>Guys,Need help. Break failure at run up area. Need the wheel and caliper model to get o ring and pads. Thanks a bunch. Sent from my iPhone |
| http://www.matronics.com/Navigator?RV10-Listhttp://wiki.matronics.com
rv10flyer
Posted: Sat Feb 25, 2017 7:06 am Post subject: Re: Break model. |
I'd like to upgrade to Matco someday, as Van's chose a marginally sized brake system.
_________________ Wayne G. |
