Kelly McMullen
Posted: Fri Feb 24, 2017 12:39 pm Post subject: Cleveland Brake parts. |
Just revising the subject line to give a break to anyone searching the
archives for Cleveland brake information.
-sent from the I-droid implanted in my forearm
On Fri, Feb 24, 2017 at 11:15 AM, Rob Kermanj <flysrv10(at)gmail.com> wrote:
[quote] Thanks guys for the quick help. On my way to abq to get the parts.
On Feb 24, 2017, at 10:01 AM, John Miller <gengrumpy(at)aol.com> wrote:
Hope this helps!
grumpy
Cleveland, Wheel 40-59A; Disc 164-07500
Grease seals: 153-00300 outer; 153-00400 inner. Snap ring 155-00100.
Lining 066-11200. Rivet 105-00200. Dust Shield 157-00900; Wheel bolts
AN5-34A; MS21044-N5 nuts
Timken Bearing LM274949-2-629, cotter pin AN 380-3-8. Torque halves 150in
lb dry
On Feb 24, 2017, at 10:52 AM, Rob Kermanj <flysrv10(at)gmail.com> wrote:
Thank you! On my way to ABQ to pick up the parts.
On Feb 24, 2017, at 9:27 AM, Home <bdgillespie215(at)gmail.com> wrote:
Not sure if this is what you are looking for.... had this noted in my POH
A&P/IA, EAA Tech Counselor
KCHD |
flysrv10(at)gmail.com Guest
Posted: Mon Feb 27, 2017 4:54 pm Post subject: Cleveland Brake parts. |
Thanks everyone for the help with break model numbers during my travel.
Best I can tell, the left caliper jammed during taxi. I could feel a wheel unbalanced condition while taxing as I sometimes notice during landing, under certain loading conditions and the right speed. So I ignored it. There was no indication of the plane dragging at all but it was a windy day and it is possible I was actually correcting for the jammed break and not the wind. Although not enough correction to be noticeable to me.
By the time I taxied to the departure point and stopped, the piston's o ring failed and fire started but I could only see white smoke. The heat bubbled the wheel pant paint and caused minor damage to the fiberglass. Having such tight wheel pants helped keep the flame from spreading and it extinguished itself in a few minutes, sooner than I could get over my shock and get the fire extinguisher from the plane. | Quote: | | Quote: |
Got the pads and O ring replaced but during the installation, noticed that the tire was melted all around near the rim, indicating that the caliper was stuck for the entire taxi period (I think...). I cannot imagine the intense heat needed to melt the tire as much as it did. Perhaps about â…›" rubber depth was gone all around from the sidewall. Unfortunately, I did not take a picture of the tire before I left it behind, in my hangar in Ruidoso.
Left disk is shot and I expect the new pads to be scored badly. Two new disks and two sets of linings are on order.
Do not archive.
On Feb 24, 2017, at 3:37 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
| Quote: | Just revising the subject line to give a break to anyone searching the archives for Cleveland brake information.
On Fri, Feb 24, 2017 at 11:15 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
| Quote: | Thanks guys for the quick help. On my way to abq to get the parts.
On Feb 24, 2017, at 10:01 AM, John Miller <gengrumpy(at)aol.com (gengrumpy(at)aol.com)> wrote:
| Quote: | Hope this helps!
grumpy
Grease seals: 153-00300 outer; 153-00400 inner. Snap ring 155-00100. Lining 066-11200. Rivet 105-00200. Dust Shield 157-00900; Wheel bolts AN5-34A; MS21044-N5 nuts
Timken Bearing LM274949-2-629, cotter pin AN 380-3-8. Torque halves 150in lb dry
| Quote: | On Feb 24, 2017, at 10:52 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
--> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)>
