Ragwing Ultra-Piet
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
cdlwingnut
PostPosted: Sat Apr 06, 2019 11:57 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
Thanks Kip
I finished the plywood strips on the wing and it is ready for the ailerons to be installed. I cut and installed the plywood on the aileron making progress on it.
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
 Filesize:  274.16 KB
 Viewed:  3509 Time(s)
 Filesize:  253.89 KB
cdlwingnut
PostPosted: Thu Apr 25, 2019 2:19 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
progress is slowing down due to the better weather making so other projects have to be done and allowing for more flying. I have been able to make some progress on the aileron though. the wood is glued to the back of the plywood now ready for the gusset strips
 Filesize:  260.68 KB
 Viewed:  3447 Time(s)
cdlwingnut
PostPosted: Fri Apr 26, 2019 2:29 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
i glued the 1.5mm plywood strips to the bottom of the aileron
 Filesize:  247.83 KB
 Viewed:  3437 Time(s)
cdlwingnut
PostPosted: Mon Apr 29, 2019 2:23 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I finished installing the cross braces for the aileron and attached the plywood on the other side. The aileron is now ready for varnish and the hinges. I had a little more time so i took a piece of aluminum angle and fabricated a heel brake peddle. We will see how it works.
 Filesize:  232.88 KB
 Viewed:  3410 Time(s)
 Filesize:  259.81 KB
cdlwingnut
PostPosted: Mon May 06, 2019 3:43 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
with one wing down i started assembly of the right wing. I got the ribs glued to the spars. I also made 2 more brake peddles, why 2 more because i made one then found out I forgot to reverse it and had a 2nd left peddle when i was done so i had to reverse it and make one more to get a right one.
 Filesize:  245.61 KB
 Viewed:  3375 Time(s)
 Filesize:  267.64 KB
cdlwingnut
PostPosted: Wed May 08, 2019 4:59 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
the compression and drag braces are now glued in place and i put the finishing touches on the brake peddles.
 Filesize:  242.3 KB
 Viewed:  3356 Time(s)
 Filesize:  227.33 KB
 Filesize:  271.11 KB
 Filesize:  260.44 KB
cdlwingnut
PostPosted: Thu May 09, 2019 6:52 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
move things around the shop a little today and did some cleaning. the fuselage is out of the little room and in the bigger part of the shop and the wing i am nearly finished on it in the little room the second wing is off the table and in the bigger part of the shop ready for the nose ribs, leading edge plywood, and all the fiddly stuff. I cut out the nose ribs.
 Filesize:  253.35 KB
 Viewed:  3327 Time(s)
 Filesize:  250.39 KB
 Filesize:  291.78 KB
taildrags
PostPosted: Fri May 10, 2019 6:59 am    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I would be interested to know what the uncovered, finished wing weighs. Pick it up and stand on your bathroom scales, then get on the scales and subtract your weight without the wing.
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
kipgohio1957(at)gmail.com
PostPosted: Fri May 10, 2019 7:08 am    Post subject: Ragwing Ultra-Piet Reply with quote
Looking good! Are you going to try to make it a legal ultralight or register it as a certificated aircraft? Once I get started on mine, I’m planning on registering it as a certificated LSA, in part because my life insurance has a specific exclusion for dying in an Ultralight accident, Lol.
On May 9, 2019, at 10:52 PM, cdlwingnut <lee_chad(at)hotmail.com> wrote:use
http://forums.matronics.com/viewtopic.php?p=489155#489155
http://forums.matronics.com//files/20190509_141226_resized_191.jpg
http://forums.matronics.com//files/20190509_153106_resized_184.jpg
http://forums.matronics.com//files/20190509_141244_resized_193.jpg
smime.p7s
 Filename:  smime.p7s
 Filesize:  1.34 KB
 Downloaded:  103 Time(s)
cdlwingnut
PostPosted: Fri May 10, 2019 2:33 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
taildrag that is a good idea I will give that a try, I am guessing somewhere in the 15 to 20 pound range but i may be wrong
Kip mine ia alreasy registered being mostly Douglas Fir and with a rotax 503 it wont make the ultra-light weight limits
oregonwissing(at)yahoo.co
PostPosted: Sat May 11, 2019 6:15 am    Post subject: Ragwing Ultra-Piet Reply with quote
Please take me off this list.
Mike
cdlwingnut
PostPosted: Fri May 24, 2019 2:32 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
the rain gave me some time to work in the shop today. I got the nose ribs glued on and the leading edge plywood for the center section measured and cut. It is now clamped and strapped to the leading edge to form before being varnished and glued in place.
 Filesize:  254.84 KB
 Viewed:  3218 Time(s)
 Filesize:  274.71 KB
 Filesize:  305.79 KB
cdlwingnut
PostPosted: Sat May 25, 2019 1:37 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
the leading edge and aileron spare are glued in place now, as well as the wingtip dowel.
 Filesize:  245.71 KB
 Viewed:  3202 Time(s)
 Filesize:  281.48 KB
taildrags
PostPosted: Sat May 25, 2019 6:28 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
All I know is, those landing gear legs with the light blue fairings look WAYYY too big for your Ultra-Piet!
Oscar Zuniga
Medford, OR
Air Camper NC41CC, A75 power
Oscar Zuniga
Medford, OR
cdlwingnut
PostPosted: Sun May 26, 2019 12:49 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I don't know they might look good with a set of spoked wheels on them
cdlwingnut
PostPosted: Wed May 29, 2019 3:25 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
I have been varnishing the area on the center wing section and the area on the wing where the leading edge plywood wrap will go and getting the center leading edge wrap varnished.
cdlwingnut
PostPosted: Tue Jun 04, 2019 4:31 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
got some T-88 mixed up over lunch and glued the leading edge plywood to the center section.
 Filesize:  250.99 KB
 Viewed:  3040 Time(s)
cdlwingnut
PostPosted: Tue Jun 11, 2019 4:18 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
with the hectic summer schedule the little piet hasn't gotten the attention it should be getting. I did get a few minutes to get the plywood gusset strips cut and glued to the top of the center section.
 Filesize:  207.16 KB
 Viewed:  2932 Time(s)
cdlwingnut
PostPosted: Wed Jun 12, 2019 4:01 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
the plywood strips for the bottom are cut and glued in place
 Filesize:  197.51 KB
 Viewed:  2918 Time(s)
cdlwingnut
PostPosted: Tue Jun 18, 2019 7:34 pm    Post subject: Re: Ragwing Ultra-Piet Reply with quote
progress has slowed down with work getting pretty busy, I suppose it is the flying season not the building season. I did get the trailing edge installed and one of the leading edge plywood pieces soaked, clamped, and strapped in place to pre-bend it.
 Filesize:  261.73 KB
 Viewed:  2814 Time(s)
 Filesize:  276.06 KB
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
Page 7 of 9
