ploucandco
Posted: Sat Feb 11, 2017 1:59 pm Post subject: ROTAX914 pressure sensor 4mm PVC tube |
Hello, I need to replace/reroute some hoses in my 914 firewall. And looking where I can find a 4mm PVC tube for the 914 pressure sensor that is supporting high temperature found in the firewall. This one needs to end up near the air filter of the turbo.
h&jeuropa
Posted: Sun Feb 12, 2017 5:12 am Post subject: Re: ROTAX914 pressure sensor 4mm PVC tube |
Rotax sells this as a replacement part (P/N 860 660), but it is very expensive and in the US few of the distributors have it in stock. There are suitable automotive hoses available.
Jim
rlborger(at)mac.com Guest
Posted: Sun Feb 12, 2017 8:40 am Post subject: ROTAX914 pressure sensor 4mm PVC tube |
I’ll bet you can find a suitable hose/tubing here:
https://www.mcmaster.com/#standard-plastic-and-rubber-tubing/=16bnwhx
if not at a good auto supply store.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Feb 11, 2017, at 3:59 PM, ploucandco <jacques(at)platisource.com (jacques(at)platisource.com)> wrote:
--> Europa-List message posted by: "ploucandco" <jacques(at)platisource.com (jacques(at)platisource.com)>Hello, I need to replace/reroute some hoses in my 914 firewall. And looking where I can find a 4mm PVC tube for the 914 pressure sensor that is supporting high temperature found in the firewall. This one needs to end up near the air filter of the turbo.Read this topic online here:http://forums.matronics.com/viewtopic.php?p=466025#466025
