Off-On-On Switch
paul(at)eckenroth.com
PostPosted: Sun Feb 05, 2017 12:17 pm    Post subject: Off-On-On Switch Reply with quote
Need some help from the experts.  I have been looking for a DPDT switch off-on-on non progressive.  It seems like such an animal does not exist.  The switch will be used for wigwag/ landing lights.  I am considering using the wig/wag module sold by Crazed Pilot.  Possibly there is another switch that with creative wiring will give off-on-on. If so please advise and include the creative wiring required.  I could go with a on-off-on and have what I need but I would like to keep all off functions down which is why I am searching for the requested switch,
Paul Eckenroth
PostPosted: Sun Feb 05, 2017 2:46 pm    Post subject: Re: Off-On-On Switch Reply with quote
Possibly B & C part number S700-2-11
http://www.bandc.aero/toggleswitch-doublepole.aspx
or
http://www.mouser.com/ProductDetail/Carling-Technologies/STG2EE-53/?qs=lk%252bUld%252bvit6bNyz8ck2TZQ%3d%3d
or
http://www.digikey.com/product-detail/en/copal-electronics-inc/ET210PA12-Z/563-1873-ND/5086777
ET210PA12-Z Datasheet:
http://www.nidec-copal-electronics.com/e/catalog/switch/et.pdf
ET210PA12-Z __ ON ON OFF
ON Connecting terminals: 2-3 , 5-6
ON Connecting terminals: 5-6
OFF Connecting terminals: None
You could call B & C and get their advice.
Joe Gores
JOHN TIPTON
PostPosted: Sun Feb 05, 2017 3:00 pm    Post subject: Off-On-On Switch Reply with quote
Paul
Would Mike bullocks idea suit you better, not needing the 'crazed pilot' wig wag
http://www.rvplane.com/?categoryid=&dayid=1145
John
----x--O--x----
Paul Eckenroth
ChuckGauthier(at)comcast.
PostPosted: Mon Feb 06, 2017 5:40 am    Post subject: Off-On-On Switch Reply with quote
This is a configuration that I used. It minimizes the panel space requirements.
Chuck Gauthier
Time: 02:56:48 PM PST US
Subject: Re: Off-On-On Switch
From: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
or
or
ET210PA12Z Datasheet:
ET210PA12Z __ ON ON OFF
ON Connecting terminals: 23 , 56
ON Connecting terminals: 56
Joe Gores
http://forums.matronics.com/viewtopic.php?p=465810#465810
Taxi,_Land,_&_Wig-Wag_plus_Nav,_Strobe_Configurations.pdf
 Filename:  Taxi,_Land,_&_Wig-Wag_plus_Nav,_Strobe_Configurations.pdf
 Filesize:  93.23 KB
 Downloaded:  760 Time(s)
jrevens
PostPosted: Mon Feb 06, 2017 11:27 am    Post subject: Re: Off-On-On Switch Reply with quote
Paul Eckenroth
Hi Paul,
You can use a 2-10 (on-on-on) switch like what Bob shows on his Z-16 drawing as a master switch. You could wire it like Bob shows in Figure 11-17 on page 11-19 of the AeroElectric Connection. That's what I did for my landing light to have the down position "off", center "landing", & up "wig-wag". You could configure whatever order you like.
John Evens
Thorp T-18 N71JE (sold)
Kitfox SS7 N27JE (built & flying)
N509RV(at)eckenroth.com
PostPosted: Mon Feb 06, 2017 2:30 pm    Post subject: Off-On-On Switch Reply with quote
Thanks everyone for the feedback.  It seems like all the switches mentioned are progressive.  Am I interpreting things correctly in that power feed to the wigwag module will of course cause the lights to wigwag.  When power is applied directly to the lights without removing the power from the wigwag module then the lights go on steady with no harm done to the wigwag module? I have the schematic from Aeroelectric for the wigwag/ landing using one switch 2-10.  Can someone explain the need for the bridge rectifier.  Also is there a source somewhere for the individual switch schematics from Carling.
Paul
On Mon, Feb 6, 2017 at 8:37 AM, Chuck - Vanc <ChuckGauthier(at)comcast.net (ChuckGauthier(at)comcast.net)> wrote:
Chuck Gauthier
Time: 02:56:48 PM PST USSubject: AeroElectric-List: Re: Off-On-On Switch
or
or
Joe Gores
PostPosted: Tue Feb 07, 2017 4:41 am    Post subject: Off-On-On Switch Reply with quote
Thanks everyone for the feedback.  It seems like all the switches mentioned are progressive.  Am I interpreting things correctly in that power feed to the wigwag module will of course cause the lights to wigwag.  If power is applied directly to the lights without removing the power from the wigwag module then the lights go on steady with no harm done to the wigwag module. I have the schematic from Aeroelectric for the wigwag/ landing using one switch 2-10.  Can someone explain the need for the bridge rectifier.  Also is there a source somewhere for the individual switch schematics from Carling.  It seems to me that with the information given in the data sheets you don't really know what you are getting.
Paul
Chuck Gauthier
or
or
Joe Gores
PostPosted: Tue Feb 07, 2017 12:34 pm    Post subject: Re: Off-On-On Switch Reply with quote
Paul,
You asked about the bridge rectifier. Can you post the schematic or a link to it?
For Carling schematics, try a Google search for "carling switch pinout".
Joe Gores
PostPosted: Tue Feb 07, 2017 1:06 pm    Post subject: Off-On-On Switch Reply with quote
Joe
Here is a link to the Aeroelectric article.  The schematic is page 3, single source, single switch.
Paul
On Tue, Feb 7, 2017 at 3:34 PM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Paul,
Joe Gores
http://forums.matronics.com/viewtopic.php?p=465873#465873
WIKI -
PostPosted: Tue Feb 07, 2017 1:56 pm    Post subject: Re: Off-On-On Switch Reply with quote
The link is missing.
Joe Gores
PostPosted: Tue Feb 07, 2017 5:42 pm    Post subject: Off-On-On Switch Reply with quote
Let me try that again.  Need to make the slight extra effort to add the link.http://www.aeroelectric.com/articles/WigWag/WigWag.pdf
Paul
On Tue, Feb 7, 2017 at 4:04 PM, Paul Eckenroth <N509RV(at)eckenroth.com (N509RV(at)eckenroth.com)> wrote:
Joe
Paul
Paul,
Joe Gores
WIKI -
PostPosted: Tue Feb 07, 2017 8:01 pm    Post subject: Re: Off-On-On Switch Reply with quote
OK, I looked at the schematic. The reason for the bridge diode is to isolate flasher terminals 2 and 3. Without the diodes, terminals 2 and 3 would be connected together and the lights would never wig-wag. They would both be on at the same time.
Joe Gores
JOHN TIPTON
PostPosted: Wed Feb 08, 2017 1:57 am    Post subject: Off-On-On Switch Reply with quote
Yes: I'm using this (page 3), now how do we convert this when I fit LEDs instead
John
----x--O--x----
On 8 Feb 2017, at 01:38 am, Paul Eckenroth <N509RV(at)eckenroth.com (N509RV(at)eckenroth.com)> wrote:
Paul
Joe
Paul
Paul,
Joe Gores
WIKI -
PostPosted: Wed Feb 08, 2017 7:44 am    Post subject: Re: Off-On-On Switch Reply with quote
According to the last page of the pdf (link provided above by Paul), the flasher will work with LEDs if a 75 ohm, 5 watt resistor is connected in parallel with each LED light.
Joe Gores
PostPosted: Wed Feb 08, 2017 11:54 am    Post subject: Off-On-On Switch Reply with quote
Thanks Joe
All I had to do was to mentally remove the bridge diode and the need becomes obvious.  I now believe I have enough information to proceed.
Paul
On Tue, Feb 7, 2017 at 11:01 PM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=465884#465884
WIKI -
