JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Fri Feb 03, 2017 4:53 am Post subject: Stall - Stall |
Hi Guys
My granddaughter has some dolls that talk, how can one modify (or construct ones own) a voice generator that says: (for obvious reasons) Stall Stall
Regards: John
alec(at)alecmyers.com Guest
Posted: Fri Feb 03, 2017 5:34 am Post subject: Stall - Stall |
You could
1. if there's a memory chip you could reprogram it, or replace it with one with your own data
2. you could replace part of the circuit with a microcontroller of your own to bash out your own audio but use the same output stage - amplifier and speaker. Two seconds of 8kHz sampled audio is 16KBytes, or half that if you use 4 bit samples. You could find a microcontroller with enough memory or use an external memory chip. Any $1 microcontroller now has a D to A, or you can bit-bash your own with a resistor ladder or 4 or 8 bit PWM output
3. you could build your own system from scratch and put it in the doll
On 3Feb2017, at 1:53 PM, JOHN TIPTON <jmtipton(at)btopenworld.com> wrote:
Hi Guys
Regards: John
http://forums.matronics.com/viewtopic.php?p=465685#465685
yellowduckduo(at)gmail.co Guest
Posted: Fri Feb 03, 2017 5:39 am Post subject: Stall - Stall |
I am using an older ISD1730 evaluation board that was around $10. from
digi-key for 3 different voice warnings on my amphib.
Today I'd start by looking at something like this
https://www.sparkfun.com/products/retired/10653
and I'd google "arduino voice recorder"
Ken
On 03/02/2017 7:53 AM, JOHN TIPTON wrote:
Hi Guys
Regards: John
Posted: Fri Feb 03, 2017 5:45 am Post subject: Stall - Stall |
Someone's done all the hard work for you ...
https://learn.adafruit.com/adafruit-audio-fx-sound-board
On 3Feb2017, at 2:36 PM, C&K <yellowduckduo(at)gmail.com> wrote:
I am using an older ISD1730 evaluation board that was around $10. from digi-key for 3 different voice warnings on my amphib.
Ken
Hi Guys
Regards: John
JOHN TIPTON
Answer 1) How ?
Answer 2). How ?
Answer 3) How ? (doll = aeroplane)
----x--O--x----
| Quote: | On 3 Feb 2017, at 01:32 pm, Alec Myers <alec(at)alecmyers.com> wrote:
You could
Hi Guys
Regards: John
JOHN TIPTON
Posted: Fri Feb 03, 2017 5:55 am Post subject: Stall - Stall |
Ken
Thank you: that's the type of answer that helps
Regards: John
----x--O--x----
| Quote: | On 3 Feb 2017, at 01:43 pm, Alec Myers <alec(at)alecmyers.com> wrote:
Ken
> Hi Guys
> Regards: John
JOHN TIPTON
Posted: Fri Feb 03, 2017 5:56 am Post subject: Stall - Stall |
Alec
Thank you
John
----x--O--x----
Ken
> Hi Guys
> Regards: John
ceengland7(at)gmail.com Guest
Posted: Fri Feb 03, 2017 6:24 am Post subject: Stall - Stall |
I've seen birthday cards that let you record your own audio message. Gutting one of those might be the easiest way to do what you want, if you have some soldering skills.
Charlie
On Fri, Feb 3, 2017 at 7:53 AM, John Tipton <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)> wrote:
Joined: 28 Mar 2008 Posts: 1970 Location: Riley TWP Michigan
Posted: Fri Feb 03, 2017 6:49 am Post subject: Re: Stall - Stall |
I have used an "ISD1820 Voice Record Module" with success:
eBay item number: 201708883118 $1.63 with free shipping.
It takes one month to ship from China.
_________________ Joe Gores |
Posted: Fri Feb 03, 2017 7:29 am Post subject: Stall - Stall |
I have used many of the Chinese knockoffs for cheap experiments or where
saving pennies is important but expect zero support for the product
other than free replacement if you get a dud.
For a one off or first time project I recommend using adafruit.com or
sparkfun.com or similar vendors to increase the chances of success with
greatly reduced aggravation.
Minor changes in some of these products can chew up a lot of time
sorting things out.
Ken
rampil
Posted: Sat Feb 04, 2017 6:30 am Post subject: Re: Stall - Stall |
All of this discussion presupposes that the OP knows how to get a signal line out of an EFIS or an AOA device, or a stall horn switch and send it to
a memory/DAC system (i.e., a voice generator) to trigger an annunciation event. It is not hard, but not trivial and depends on the specifics of the
target hardware
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Sat Feb 04, 2017 7:31 am Post subject: Re: Stall - Stall |
Great subject. DX.com has several of these for a few bucks. They have reasonably fast shipping.
Two thoughts: This is a perfect place to put a perfect female voice from a coworker, sister, friend, etc.
The Air Forces uses audio warnings extensively. The potential uses for these is mind boggling.
A Guerrilla group in San Francisco bought a load of GI Joes and Talking Barbies and swapped the chips and returned them for credit. Now the GI Joes said sweetly, "Let's go shopping!" and the Barbies said, "Take that hill !"
Eric
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Sat Feb 04, 2017 9:33 am Post subject: Stall - Stall |
Lots of room to have fun but I had to use my own voice.
We males may be programmed to pay more attention to female voices but
the ones around me were too smart to let their voices become "bitch'in
betty"
Of course a large part of audio warning success is to avoid nuisance
warnings that train our brains to ignore them.
Ken
On 04/02/2017 10:31 AM, Eric M. Jones wrote:
Eric
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=465743#465743
billhuntersemail(at)gmail Guest
Posted: Sat Feb 04, 2017 9:34 am Post subject: Stall - Stall |
In the late 1970's when we were living in Silicon Valley my dad had a start up high tech electronics firm. Since he was in the business he had lots of friends from all over the world who were all in Silicon Valley dreaming up all kinds of futuristic ideas.
One such friend came over one night and he had a very small PC board with an integrated chip and a small microphone. This device would capture about 5 to 10 seconds of audio and record it in solid state on the chip... wow... no spinning records or magnetic tape.
We all sat around the kitchen table and played with it and laughed and try to dream up ways that this device could be used. We had such ideas as a teddy bear, greeting card, Christmas ornament but that was about the extent of our creativity.
Fast forward 20 to 40 years and it is shocking that so many devices still use a goofy synthetic voice to say things like "autopilot" or "too low flaps" instead of a device with a recorded sexy female real person voice.
Bill Hunter
On Feb 4, 2017 08:40, "Eric M. Jones" <emjones(at)charter.net (emjones(at)charter.net)> wrote: | Quote: | --> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net (emjones(at)charter.net)>
Eric
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
WIKI -
Posted: Sat Feb 04, 2017 9:45 am Post subject: Stall - Stall |
I also just remembered that in the late 1990s I was interviewing for a corporate Jet Pilot position with a Silicon Valley firm that was purchasing their first jet.
During the interview I asked what their product line was and the principle explain to me that they had just invented a computer chip that could record 1000 songs on it. I remember him looking across the conference table and pointed to his thumbnail and said that this ship was only the size of a person's thumb nail and that it could record 1000 songs. I was amazed because a compact disc at the time would only record 40 songs.
He said that he could not elaborate more about the product nor could he tell me what other companies he was going to be a vendor for with this revolutionary new product.
Bill Hunter
On Feb 4, 2017 10:31, "William Hunter" <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote: | Quote: | In the late 1970's when we were living in Silicon Valley my dad had a start up high tech electronics firm. Since he was in the business he had lots of friends from all over the world who were all in Silicon Valley dreaming up all kinds of futuristic ideas.
Bill Hunter
Eric
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
WIKI -
Posted: Sat Feb 04, 2017 9:52 am Post subject: Stall - Stall |
No voice actor royalties.
On a more serious note. There was an article some months ago about a DIY stick shaker. I wonder if that might be a more effective alert tool for stall warning than any visual or audio alert. I'd never considered making one, but the execution would be relatively simple, as long as you have a signal source.
Charlie
On Sat, Feb 4, 2017 at 11:31 AM, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Bill Hunter
