kearney
Posted: Mon Jan 30, 2017 1:00 pm Post subject: Static System Icing |
Hi
A few days ago I was flying for a couple of hours in -7c wx (19F for those south of the 49th). Everything was uneventful until I was on a downwind to land when my static line became blocked.
Fortunately my annual was only a couple of days away so I checked things out when I had everything opened up for inspection. I found a 1/4" column of water in the static line low point in the tail cone. As it was well below freezing there the line must have frozen thereabouts.
A quick blast of air (from the panel end of the line) and the water was gone.
I thought I'd mention this as something to watch for.
Cheers
Les
Dave Saylor
Posted: Mon Jan 30, 2017 5:29 pm Post subject: Static System Icing |
Yeah, it's bad enough dealing with erroneous information ourselves, but in these days of powerful autopilots, you have to make sure it doesn't get confused either.
--Dave
On Mon, Jan 30, 2017 at 1:00 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
| Quote: | --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=465577#465577
WIKI -
_________________ --Dave
KWVI |
gengrumpy
Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
Posted: Mon Jan 30, 2017 7:08 pm Post subject: Static System Icing |
Most interesting. Wonder how that got there? Condensation?? Rain???
grumpy
| Quote: | On Jan 30, 2017, at 7:28 PM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
--Dave
On Mon, Jan 30, 2017 at 1:00 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote: | Quote: | | --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> Hi A few days ago I was flying for a couple of hours in -7c wx (19F for those south of the 49th). Everything was uneventful until I was on a downwind to land when my static line became blocked. Fortunately my annual was only a couple of days away so I checked things out when I had everything opened up for inspection. I found a 1/4" column of water in the static line low point in the tail cone. As it was well below freezing there the line must have frozen thereabouts. A quick blast of air (from the panel end of the line) and the water was gone. I thought I'd mention this as something to watch for. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=465577#465577 ==================================== -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List ==================================== FORUMS - eferrer" target="_blank">http://forums.matronics.com ==================================== WIKI - errer" target="_blank">http://wiki.matronics.com ==================================== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ==================================== |
