iCom Antenna Switchbox effect on Com Radio
PostPosted: Wed Jan 25, 2017 10:17 am    Post subject: iCom Antenna Switchbox effect on Com Radio Reply with quote
At 11:37 AM 1/25/2017, you wrote:
Bob,
Thanks for discussing this subject.
I'm having trouble with my SL30 not receiving and transmitting and had assumed the problem to be with the radio. After your discussion I remembered I wired in one of the iCom boxes and it well could be the problem.
It certainly warrants investigation. Do
you have a BNC barrel adapter . . . or perhaps
a BNC-Tee? You can pull the coaxes off the
back of the Icom-Box and bypass it with
the connectors.
Let us know what you discover.
An SWR check at the radio end of the feed
line would be equally useful. These things
are coming down in price . . . and this offering
even ships from US.
http://tinyurl.com/j7muztq
You'll need a pair of BNC(F)->N(M) adapters
http://tinyurl.com/h3666vz
hlbartel(at)pld.com
PostPosted: Wed Jan 25, 2017 11:20 am    Post subject: iCom Antenna Switchbox effect on Com Radio Reply with quote
Bob,
I need an education. The SWR meter referenced here shows; Frequency Range: HF 1.6MHZ~60MHZ. How important are the range markings?
Harry
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Wednesday, January 25, 2017 12:12 PM
Subject: Re: Re: iCom Antenna Switchbox effect on Com Radio
Bob,
the connectors.
even ships from US.
PostPosted: Wed Jan 25, 2017 5:21 pm    Post subject: iCom Antenna Switchbox effect on Com Radio Reply with quote
Bob,
the connectors.
even ships from US.
alec(at)alecmyers.com
PostPosted: Thu Jan 26, 2017 5:06 am    Post subject: iCom Antenna Switchbox effect on Com Radio Reply with quote
Is there any significant benefit of a digital meter over an analogue one? Ive never trusted the fake precision of cheap digital meters.
On Jan 25, 2017, at 14:41, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Bob,
the connectors.
even ships from US.
PostPosted: Thu Jan 26, 2017 12:07 pm    Post subject: iCom Antenna Switchbox effect on Com Radio Reply with quote
But this unit always did show 1.02 when trying to calibrate with 1W and even with other power settings he never did see a VSWR which was to expect and tells the unit is useless for measuring VSWR.
I'm surprised at this . . . I'm wondering if
the device under test was broke. I'm ensnarled
in some house-projects right now . . . I'll
dig out my red-dot and run the same tests
on it in the next day or so.
So I probably should go better with a standard box like DAIWA CN-102 L?
Without digging into the internals and/or
doing bench testing, I can offer no
additional insight. The red-dot series
has been out there for several years.
I searched a bit for technical reviews but
couldn't come up with anything in the time
I had to look.
If anyone out there can find a published
narrative on a technical bench test of the
red-dot (or any similar instrument) it would
be a useful addition to the archives.
PostPosted: Fri Jan 27, 2017 9:50 am    Post subject: iCom Antenna Switchbox effect on Com Radio Reply with quote
At 03:59 PM 1/26/2017, you wrote:
I would imagine the MFJ-259 would be of limited application when testing at the transponder frequency, given it's normal application doesn't extend above VHF? I have the later MFJ-269, that does reach up into the lower part of UHF but only gives SWR results at that frequency.
Correct . . . I mentioned the MFJ259 as an
EXAMPLE of self excited network analyzer (read
SWR meter). At the same time, I was agreeing with
the comment that while the bare-foot VHF/UHF
analyzers can use the host comm transceiver as
a constant excitation source, a transponder offers
no such capability.
