wschertz343(at)gmail.com Guest
Posted: Wed Jan 04, 2017 11:00 am Post subject: Conduit and adding wires |
One other technique for adding a wire to an existing conduit if you don't
have the embedded string is to take a length of 1/4" polyethylene tubing,
run it down the existing conduit (may have to occasionally turn it) it is
stiff enough to allow you to install it, then run the wire into the tube,
fasten the far end and pull the tube back out. The slippery nature of the
tubing makes pushing the wire through easy,.
Bill Schertz
