				 Posted: Thu Dec 08, 2016 5:54 am    Post subject: Main oil screen and remote filter |
				Greg,
 If you are talking about the main oil screen on the Yak 52, removing it
 would prevent the oil from flowing between the oil tank and the oil
 pump.  The main oil screen, when inserted into the canister on the
 firewall, actually opens a spring loaded valve which when opened, allows
 the oil to flow via gravity into the main oil screen.  So yes, removing
 it wouldnot only be odd, but would most likely cause some serious engine
 damage. 1st indication would be no oil pressure.
 What seems to be common practice is to install the add-on oil filters
 (Airwolf or canister type)between the output of the oil cooler and the
 oil tank.  Where they should be installed is on the output of the oil
 pump (scavenge pump side) between there and the input of the oil cooler.
 Dennis
 A. Dennis Savarese
 334-546-8182 (mobile)
 www.yak-52.com
 Skype - Yakguy1
 On 12/8/2016 7:23 AM, greg.barnhard(at)gmail.com wrote:
  Has anyone ever heard of removing the main oil screen (in the canister on the firewall) when installing a remote oil filter (air wolf) to prevent excessive restrictions in the lines? Correct me if I'm wrong but that's the only screening of the oil between the tank and the motor. Removing that seems odd.
  Greg
  http://forums.matronics.com/viewtopic.php?p=463779#463779
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		cjpilot710(at)aol.com Guest
				 Posted: Thu Dec 08, 2016 11:21 am    Post subject: Main oil screen and remote filter |
				Are you talking about the cylinder shaped wire screen, that's horizontal at  the back of the engine case?
  Pappy
   In a message dated 12/8/2016 7:24:12 A.M. Eastern Standard Time,  greg.barnhard(at)gmail.com writes:
   	  | Quote: | 	 		  -->    Yak-List message posted by: "greg.barnhard(at)gmail.com"    <greg.barnhard(at)gmail.com>
 Greg
 Read this topic online    here:
 http://forums.matronics.com/viewtopic.php?p=463779#463779========================nbsp;             (And Get Some AWESOME FREE     to find   Gifts       ilder's  ELP  k you for  p;                        -Matt Dralle,    List  ========================  e  ties  Day  ================================================               - MATRONICS WEB FORUMS  ================================================              - NEW MATRONICS LIST WIKI -_-=                - List Contribution Web Site  sp;                             ===================================================
				 Posted: Thu Dec 08, 2016 11:31 am    Post subject: Main oil screen and remote filter |
				I agree with Dennis.  With the filter mounted on the output of the oil  pump, what you are getting in reality
   is the hot dirty oil right out of the engine.  The oil being  thinned out, the particulates are more easily trapped in the filter, thus  the whole stays cleaner from the filter down stream - oil cooler - oil tank and  all lines including those back to the engine itself.
  Jim "Pappy" Goolsby
   In a message dated 12/8/2016 8:55:51 A.M. Eastern Standard Time,  dsavarese0812(at)bellsouth.net writes:
   	  | Quote: | 	 		  -->    Yak-List message posted by: "A. Dennis Savarese"    <dsavarese0812(at)bellsouth.net>
 Greg,
 Dennis
 A. Dennis Savarese
 www.yak-52.com
 Skype - Yakguy1
     Greg
		ariekert
				 Posted: Fri Dec 09, 2016 12:51 pm    Post subject: Re: Main oil screen and remote filter |
				Gents,
 I'm planning a remote filter installation too. Looking for a basic remote filter base and even more for a way to connect to the existing russian system.
 The Airwolf system comes in a -10AN and a -12AN version. Any considerations about the size in respect of the additional drag introduced by more hose and the filter that you may want to share?
 Is there a chance that the M-27 russian fitting of the oil-hose going to the filter might fit to a MIL 6000-10 hose?
 Any other way to connect the US-size hose to the russian fittings that you may think of?
 Any help would be greatly appreciated.
 Armin
  Jim "Pappy" Goolsby
   	  | Quote: | 	 		  -->    Yak-List message posted by: "A. Dennis Savarese"    <dsavarese0812>
 Greg,
 Dennis
 A. Dennis Savarese
 www.yak-52.com
 Skype - Yakguy1
  	  | Quote: | 	 		   --> Yak-List message posted by:    "greg.barnhard(at)gmail.com" <greg>
     Greg
 _-=                - List Contribution Web Site  sp;                          �  ===================================================
  | 	  [/quote]
