Built-in Oxygen (Mountain High)
philperry9
PostPosted: Fri Dec 02, 2016 8:36 am    Post subject: Built-in Oxygen (Mountain High) Reply with quote
For those of you who have installed the EDS-4ip system from Mountain High, have any of you found a method to shove the tubing over the barbs fully?
I've never given birth to a child, personally, but I'm pretty sure this is what it's like.
Hopefully there is a well-known lubricant out there that won't damage the electronics inside the distribution units.
Or perhaps you can give me a tip to become more dilated. Either way, something has to give.
Phil
Tim Olson
PostPosted: Fri Dec 02, 2016 8:59 am    Post subject: Built-in Oxygen (Mountain High) Reply with quote
I don't have that system but I've always slightly warmed the tubing with a heat gun....carefully. I bought some of that tubing type and I think that would help a lot. Don't warm it too far back or it gets too flexible on the pushing area.
Tim
Phil
philperry9
PostPosted: Fri Dec 02, 2016 9:29 am    Post subject: Built-in Oxygen (Mountain High) Reply with quote
That's the secret. The heat worked.
We don't plan on having any more kids. But just in case we do, I'm going to keep a spare heat gun behind the seat of the truck.
It's way cheaper and faster than medication....
Tim
> Phil
> Sent from my iPhone
flying-nut(at)cfl.rr.com
PostPosted: Fri Dec 02, 2016 9:42 am    Post subject: Built-in Oxygen (Mountain High) Reply with quote
Not familiar with the system specifically, but when faced with barbed
fittings I dip the ends of the tubing in boiling water and the barbs
seem to go in easily.
Linn
Phil
