Posted: Mon Oct 31, 2016 3:26 pm Post subject: BatteryMinder not recommended for use in aircraft |
At 05:06 PM 10/31/2016, you wrote:
| Quote: | --> AeroElectric-List message posted by: Lyle Peterson <lyleap(at)centurylink.net>
The fire was on the 29th at about 12:20pm. A homebuilt and a Cessna 182 were destroyed. I received three pictures. One was the exterior of the hangar. It is still standing but the upper level is blackened. Of the homebuilt only the tail section remains as recognizable as part of an airplane. The rest is mostly ashes. It appeared to be a composite aircraft. There was no image that was clearly of the 182
The fire is being investigated. Most likely there will be no report on the news regarding the cause. Airport tenants and the management will most likely have the report when it is released. |
Was a 'battery charger/maintainer' even mentioned
as a possible participant in the fire?
