donjohnston
Posted: Mon Oct 31, 2016 2:19 am Post subject: BatteryMinder not recommended for use in aircraft |
I just got a new BatteryMinder because the old one couldn't push enough electrons for the new battery. Oh well.
But the new BatteryMinder didn't come with the ring terminal harness. Just the big alligator clips. I figured that they were charging (pun intended) extra for the harness.
But then I found out that they do not recommend using the charger on batteries in the plane. From their manual (emphasis theirs):
1. Attach output cord of charger to the battery clip(s) assembly (BCAA) (supplied). For aviation applications, we no longer advise use of the RTA on any batteries while the battery is located within a confined area, such as in an aircraft engine compartment.
2. Battery should be removed from aircraft or open to free flowing air to avoid possible build-up of harmful hydrogen gas in the event battery has a shorted cell(s) or charging source is incorrect or malfunctions.
I can't imagine that people are actually going to remove their battery every time they want to hook up the BatteryMinder. In my case the battery is in the nose. With the nose gear door open and the upper access hatch open I've got a pretty good flow of air.
But that hangar fire at KANE which is being attributed to a BatteryMinder does raise a doubt. A battery is a lot cheaper than a new plane.
bobnoffs
Joined: 04 Jul 2012 Posts: 132 Location: northern wi.
Posted: Mon Oct 31, 2016 2:58 am Post subject: BatteryMinder not recommended for use in aircraft |
get a little fan for $15 that pulls 15 watts 120 acv and rig it up so your ''enclosed space'' is ventilated. otherwise a tender is useless for me.
bob noffs
On Mon, Oct 31, 2016 at 5:19 AM, donjohnston <don(at)velocity-xl.com (don(at)velocity-xl.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
http://forums.matronics.com/viewtopic.php?p=461757#461757
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
