capedavis(at)yahoo.com Guest
Posted: Thu Oct 13, 2016 6:21 pm Post subject: FIREFLY FLAPERONS |
Kolbers ran into another problem building my FIREFLY today, built the push pull shaft for the flaperons and when I went to hook them up they were the right length and the ends fit but not at the same time the control handle is bolted to the cockpit frame tapering towards the nose and the shaft runs back to the sliding flaperon control they are about thirty degrees out of alignment! I could bend the control handle as its just a piece of 3/32s steel but that doesnt seem like it would be right ? Anybody know what I should do or what I might have done wrong? I hope you understand my description thank for reading it . Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Herbgh(at)nctc.com Guest
Posted: Thu Oct 13, 2016 6:46 pm Post subject: FIREFLY FLAPERONS |
depends on what you mean by they?  Ailerons seem to be the only thing that could be out of alignment with the way the mechanism works.. the only other "they" would be the two brackets that hinge on the boom tube through bolt.. and attach to the tube that slides on the aileron torque tube?Â
 Probably need a better description? What is "They".  Herb
On 10/13/2016 09:21 PM, chris davis wrote:
| Quote: | Kolbers ran into another problem building my FIREFLY today, built the push pull shaft for the flaperons and when I went to hook them up they were the right length and the ends fit  but not at the same time the control handle is bolted to the cockpit frame tapering towards the nose and the shaft runs back to the  sliding flaperon control they are about thirty degrees out of alignment! I could bend the control handle as its just a piece of 3/32s steel but that doesnt seem like it would be right ? Anybody know what I should do or what I might have done wrong? I hope you understand my description thank for reading it . Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny."
Aristotle
"Daddy, tell me...why are you going to the pig farm for a reeducation and what does it mean "A basket of deplorables"? "Are you unreedemable"? And" who is Stalin and Mao Zedong"? Mark Twain's GGgranddaughter...
Posted: Fri Oct 14, 2016 8:19 am Post subject: FIREFLY FLAPERONS |
Herb I wrote the email late last night so my discription suffered I will draw a picture and print it and then send it to the list Thanks Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
byoungplumbing(at)gmail.c Guest
Posted: Fri Oct 14, 2016 8:25 am Post subject: FIREFLY FLAPERONS |
you may want to send a photo On Oct 13, 2016 8:47 PM, "Herb" <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote: | Quote: |
Chris Davis
KXP 503 492 hrs
Glider Pilot
Aristotle
