victorbravo(at)sbcglobal. Guest
Posted: Mon Oct 10, 2016 3:27 pm Post subject: More HKS Engine Interference Questions |
Hi again Kolb List, I spent several hours out at the hangar trying to figure out the correct mounting for the HKS engine that will clear the wing parts when folded. I need an answer to another question from those who have been downt his road with the HKS.
What is the acceptable height of the propeller shaft / thrust line on the Firestar, as measured from the Kolb rubber engine mounts, or from the main engine mount support tube on top of the fuselage ?
I was and I am in 100% agreement with the many Kolb List experienced pilots who have said that too high of a thrust line causes problems.The lower the thrust line, the better the airplane flies.
However, even with the aileron torque tubes rotated or moved out of the way during wing folding, the bottom of the HKS exhaust pipe just under the exhaust port is in contact with the inboard "root rib" area of the trailing edge.
Moving the engine FORWARD on the fuselage will solve this problem, but the propeller will hit the bottom of the steel cage just above the tailboom tube.
Raising the engine several inches will also solve this interference problem, but then the thrust line may become high enough to change how the airplane flies.
So the question is... how high can the propeller thrust line be on a Kolb Firestar 2 without causing a change in the aircraft handling?
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net - winning proposals for non-profit and for-profit entities
On Mon, 10/10/16, Richard Pike <thegreybaron(at)charter.net> wrote:
Subject: Re: syncro of carbs
Date: Monday, October 10, 2016, 9:11 AM
"Richard Pike" <thegreybaron(at)charter.net>
racerjerry wrote:
> I think the confusion is that we are not used to
looking at a CLOSED SYSTEM.
> There is no vent to atmosphere and hoses fit tightly
into bottles. If vacuum on one bottle is
greater, fluid will flow into that bottle. If carbs
are adjusted equal, fluid flow between bottles will
stop. Fluid level does not matter. Fluid
transferring between bottles means carbs are not balanced.
Makes perfect sense. Imbalance of vacuum=movement. Lack of
movement=balance. Thanks, got it.
HOWEVER ~ (Much mental activity going on here... sound
of gears grinding...) ~ I am thinking that in order to know
that your carbs were in fact perfectly balanced, you would
have to balance the carbs, open the system, reconnect the
system, and run the engine again.
Here is why: even in a closed system, the levels of liquid
would still seek to be even with each other, because if one
liquid level was higher, it would want to siphon until both
levels were equal, but it can't. If one bottle was higher,
it would want to siphon into the lower, but because the
system is closed, it cannot level itself. However, gravity
is still placing an inherent imbalance on those liquid
levels. That gravity imbalance manifests itself as a
pressure differential, and that is what we are measuring
when we balance our carbs.
In our situation, if the levels stabilize at an unequal
height during adjustment, I think it is going to preclude
getting a perfect carb balance because now we have to factor
in a pressure differential caused by unequal weights of
liquid in the two bottles. Even in a closed system, that
pressure differential still has to be a factor somewhere.
Let's say you start with both bottles level, liquid levels
the same, hook it up and run the engine. Carbs not balanced,
siphon occurs and the bottle with the highest vacuum begins
to fill. You adjust the carbs for balance, and
siphon/transfer stops. But if one bottle is now 1/3 full and
the other bottle is 2/3's full, then there is a weight /
pressure imbalance which my carb vacuum settings have to
compensate for. One bottle has a much greater weight of
liquid, which is seeking its own level, but my carb setting
is preventing that from happening. Which implies to me that
my carb setting cannot be perfectly balanced if it is
compensating for a weight imbalance / pressure differential.
So if I was doing it, at this point I would shut down the
engine, disconnect the tubing, let the liquid
siphon/transfer occur until both bottles have level liquid,
then hook the system up again, run the engine, and if the
carbs are in fact balanced, no transfer would occur, and the
liquid levels would stay the same.
Then I could quit worrying about it. [Wink]
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Would you consider yourself to be a good person?
https://www.youtube.com/watch?v=VWcDXT6pH7A
http://forums.matronics.com/viewtopic.php?p=461124#461124
Forum -
- MATRONICS WEB FORUMS -
MATRONICS LIST WIKI -
List Contribution Web Site -
-Matt
Dralle, List Admin.
lcottrell
Posted: Mon Oct 10, 2016 3:49 pm Post subject: More HKS Engine Interference Questions |
Bill Berle
| Since I am one of the few that have an HKS, I guess that I will have to tell you again that I have mine with 2 inch risers, swing a 66 inch prop giving me about 3/4 of an inch clearance.
As to your question about how high- I cannot tell you that as I have not gone there as of yet. I can tell you that my wings will fold by turning the ailerons in the extended position when it is folded. I can also tell you that with the engine set the way that it is, when I give it full throttle the plane climbs without my influence on the stick. So apparently I have not raised it too high yet.
I once rode in a Mark three that when full throttle was applied the plane dived without stick up pressure. It scared me!
Larry
stuart(at)harnerfarm.net Guest
Posted: Mon Oct 10, 2016 4:02 pm Post subject: More HKS Engine Interference Questions |
Just a thought.
Move the engine forward to clear the exhaust. Use a spacer to move the prop backward enough to clear the rear spar.
Stuart
lcottrell
Posted: Mon Oct 10, 2016 5:31 pm Post subject: More HKS Engine Interference Questions |
Stuart thanks for the reminder.
I forgot a few things. As far as I can tell the engine plate is a standard one from Kolb. I know that it fits a 503 as well as the HKS. The HKS bolts are 3 1/4 inches forward on the plate, and seem to be centered equally. I also got a prop extension from Rick that I like a lot. It is 2 1/2 inches long.
Larry
Posted: Mon Oct 10, 2016 10:12 pm Post subject: More HKS Engine Interference Questions |
Thank you Larry and Kolb List'ers for the responses.
Larry I did remember you told me you had two inch spacers... however I measured my installation, and going from the one inch spacers (what I have now) to two inch spacers (what you have) will still not raise the exhaust pipe UPWARD enough to clear the trailing edge tube of the wing (even with the aileron swung out of the way).
The problem is only with the wings folded back for storage or trailering. There's PLENTY of clearance in flying configuration.
Because of the offset between right and left cylinders on an opposed engine, the left wing is a bigger interference problem than the right wing.
The engine might have to go forward, and that means I will have to use a prop extension so the prop doesn't hit the rear of the steel cage. Does anyone know whether I can use a 3 or 4 inch extension on the HKS without putting too much load on the crankshaft or main bearings?
Thank you guys for helping solve this problem. Does any one know whether David Bigelow (HKS powered Firestar 2 in Hawaii) is still flying or participating in this group?
Bill Berle
On Mon, 10/10/16, Larry Cottrell <lcottrell1020(at)gmail.com> wrote:
Subject: Re: More HKS Engine Interference Questions
To: "kolb-list(at)matronics.com" <kolb-list(at)matronics.com>
Date: Monday, October 10, 2016, 4:48 PM
aircraft handling?
Bill Berle
yet.
pressure. It scared me!Larry
Posted: Mon Oct 10, 2016 10:28 pm Post subject: More HKS Engine Interference Questions |
I may have found the problem why Larry's installation is different than mine !
The hotos he was kind enough tos end show exhaust pipes that are NOT separated just past the exhaust port. Mine have a break, with a "Swivel joint" and springs, just 2 inches outside of the exhaust port. These undoubtedly take up more room, and make the exhaust pipe hang down a couple of inches lower under the engine, than Larry's "solid, no swivel/spring joint" system.
So in order to have the thrust line in the best possible position (so I can get the great Kolb handling that I've been hearing about), I may wind up having to make up a new exhaust system that takes up less space, or routes the exhaust pipes a different direction, etc..
Bill Berle
aircraft handling?
Bill Berle
yet.
lcottrell
Posted: Tue Oct 11, 2016 5:28 am Post subject: More HKS Engine Interference Questions |
Have you checked with Jerry (at)Green Sky? He may be able to supply the pipes that I have. That would have been my only option with my remote location. I am sure there are a few more muffler shops where you are.Larry
On Tue, Oct 11, 2016 at 12:22 AM, Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)> wrote:
| Quote: | --> Kolb-List message posted by: Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
Bill Berle
On Mon, 10/10/16, Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
To: "kolb-list(at)matronics.com (kolb-list(at)matronics.com)" <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
aircraft handling?
Bill Berle
yet.
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
The older I get, the less tolerant I am of those who are intolerant of others.
Posted: Tue Oct 11, 2016 9:09 am Post subject: More HKS Engine Interference Questions |
Yes we have plenty of welding and muffler shops here, I'm sure I can get anything I need made. I have an FAA/Boeing/Lockheed approved weld shop that does my certified airplane parts. Larry if you are stuck and you need something made to a drawing, I can definitely put you in the right hands.
To be honest, this whole interference thing has been making me crazy (crazier), since I have photos of at least two good HKS installations on this same FS2 airframe without creating this problem. I just couldn't imagine everyone else having to scratch their head over this for months like I did.
So now... since I will have to modify or change the exhaust system (because the one I got with the engine will not work as-is).... the question becomes: Where is the very best possible place to route the exhaust and mount the muffler on the Firestar/HKS combination?
I have read Larry's postings and e-mails (thank you!) with an explanation of how he feels the muffler prevented enough airflow from getting to the cylinders when it is mounted in front of the engine. Larry also mentioned that it created a lot of drag, which he had to fix using an airflow baffle plate behind it.
So perhaps the top of the wing in front of the engine is not a good place for the muffler on this aircraft?
Has anyone mounted the muffler underneath the bottom of the fuselage, at the intersection of the steel cage and fuselage tube ? This would put the muffler a lot further away from blocking airflow to the cylinders (and keep the noise further away from the pilot's head), at the cost of another four feet of tubing weight.
I have planned on using an aluminum muffler to reduce weight, because all of you on the Kolb list have convinced me that reducing weight is a primary consideration. The stock HKS cylindrical steel muffler weighs at least 12 pounds by my estimate, and an equivalent aluminum one might be half that. That's a big chunk of weight that can be removed, even if the muffler will not last as long as steel would.
What do you guys think is the best possible location for the exhaust and muffler, if you had the chance to start with a clean sheet of paper?
Bill Berle
Date: Tuesday, October 11, 2016, 6:28 AM
you are.Larry
at 12:22 AM, Bill Berle <victorbravo(at)sbcglobal.net>
Bill Berle
www.grantstar.net
entities
Questions
line
aircraft handling?
Bill Berle
have
you
it
the
yet.
-List" rel="noreferrer"
target="_blank">http://www.matronics.com/
Navigator?Kolb-List
FORUMS -
eferrer"
target="_blank">http://forums.matronics.com
WIKI -
errer"
target="_blank">http://wiki.matronics.com
b Site -
rel="noreferrer"
contribution
The
If you forward this email, or any part of
it, please remove my email address before sending.
neilsenrm(at)gmail.com Guest
Posted: Tue Oct 11, 2016 10:59 am Post subject: More HKS Engine Interference Questions |
Bill/All
When I was building my VW powered MKIIIC I put a motor cycle glass pack muffler on my engine. I started with a dune buggy 4 in to one system that I reworked a bunch to get it to fit. I couldn't see putting the big heavy steel muffler on my airplane so I put a glass pack motorcycle muffler on it. Later on I discovered that the glass had blow out of the muffler but the engine wasn't any louder. So my next step was to eliminate the muffler completely. The engine produced more power, the plane is lighter and was again no louder.
The noise from my VW comes from the prop and engine vibrations coming through the rubber engine mount, but that's another story. With a pusher engine can you hear the exhaust over the prop noise? I can't hear mine in the cockpit and my fly over noise at 60% cruise power is quieter than the average Cessna. So do you even need or want a muffler???
Have you 912 guys ever flown without a muffler? The 2 stroke engines a different animal and are tuned for the back pressure. Maybe the higher RPM engines need a bit of silencing?
Rick Neilsen
Redrive VW Powered MKIIIC
On Tue, Oct 11, 2016 at 1:09 PM, Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)> wrote:
Bill Berle
On Tue, 10/11/16, Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
you are.Larry
Bill Berle
www.grantstar.net
entities
Questions
line
aircraft handling?
Bill Berle
have
you
it
the
yet.
Navigator?Kolb-List
FORUMS -
eferrer"
WIKI -
errer"
b Site -
rel="noreferrer"
contribution
The
FORUMS -
WIKI -
b Site -
lcottrell
Posted: Tue Oct 11, 2016 3:39 pm Post subject: More HKS Engine Interference Questions |
Sorry today was town day, and that takes all day.
The placement of the muffler causes more problems than it solves. It screws up the wind needed to cool the engine, and slows the plane. I do not know if this engine needs a muffler? ( back pressure etc) If it didn't I would be thinking about collecting the two pipes in the middle between the cage and the prop having it come out below the boom tube. I would still put the oil cooler on the back of the cage however.
You still may need to cover and funnel the wind over the cylinder heads, if so let me know because I have drawings of the cover needed for that.
Larry
Richard Pike
Posted: Tue Oct 11, 2016 4:02 pm Post subject: Re: More HKS Engine Interference Questions |
| lcottrell wrote: | Sorry today was town day, and that takes all day.
Larry |
This particular thread has me really interested, even though I don't own an HKS. Larry; can you post a picture or two of your HKS on the airplane? Would like to see it.
Kingsport, TN 3TN0
Posted: Thu Oct 13, 2016 7:38 pm Post subject: More HKS Engine Interference Questions |
Brother Jim and I mounted the first 912 on a MKIII. There were no aftermarket exhaust systems available in 1993. Jim welded up four 18" exhaust stacks. 180 degrees out the exhaust port and a 90 degree bend to make them exhaust out the left and right side. Sounded great on the ground, but at 5000 RPM on the flight from Titus, AL, to Lakeland, FL, the top of my head was ready to come off. Don't know if any of you all were at S&F 1994. The 912 sounded like a Formula One screaming down the straightway at WOT. Did sound good, but was God awful loud. Homer Kolb loved it, but the UL police at Paradise City didn't. They complained to me, but Homer said don't worry about it.
Was nice to get an aftermarket exhaust that was somewhat more quieter.
MKIII
Beatty, Nevada
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen
Sent: Tuesday, October 11, 2016 12:58 PM
Bill/All
Rick Neilsen
Bill Berle
you are.Larry
Bill Berle
www.grantstar.net
entities
Questions
line
aircraft handling?
Bill Berle
have
you
it
the
yet.
Navigator?Kolb-List
FORUMS -
eferrer"
WIKI -
errer"
b Site -
rel="noreferrer"
contribution
The
FORUMS -
WIKI -
b Site -
<![if !supportLineBreakNewLine]><![endif]>
_________________ John Hauck
Titus, Alabama |
