Posted: Wed Oct 12, 2016 12:19 pm Post subject: Can One Oil Temp Resistance Bulb Run Two Instruments? |
At 01:15 PM 10/12/2016, you wrote:
| Quote: | | Thanks Bob, I expect you're right. I may set up a simple bench-top experiment just to see how much each gauge under reads with the bulb in a pot of boiling water. |
Be still my beating heart . . . you're a good man
Charlie Brown! Experimentation, measurement and
verification is one of foundations for progress.
I seem to recall a similar thread although many
moons ago and I'm not sure it was here on the
List . . . it may have been on the Compuserve
AVSIG . . . that goes back a few years.
I think what we decided was that the master
gage was essentially a voltmeter . . . that
produces a needle position in concert with
a temperature/resistance characteristic
of the matching transducer.
I think one of the guys built a gain-of-one
buffer amplifier on a piece of perf board.
Input to the amplifier was a 'sample' of the
voltage at the master-gage sensor terminal.
This voltage voltage was simply repeated and
and passed on to the slave-gage without disrupting
of the master gage.
This was used successfully on a variety of
Rochester-like, moving magnet gages for
a host of measurements. No calibration required,
just gages proven to be identical.
While conducting your bench tests, it would be
useful to know the sensor signal's current
as well as voltage drop across the sensor
at the 100C test point. You'll need to get
a milliammeter in series with the sensor.
I can help with parts selection and a schematic
once that data is known.
Posted: Fri Oct 14, 2016 1:08 pm Post subject: Can One Oil Temp Resistance Bulb Run Two Instruments? |
Here's an article by an individual
wrestling with understanding/calibration
issues on VDO automotive gages.
http://tinyurl.com/h4qo22g
It would be interesting to 'characterize'
the gages you have in hand by measuring
the current through the gage over the
instrument's calibration span.
