Thermostatic switch/relay
trigo(at)mail.telepac.pt
PostPosted: Sat Oct 08, 2016 3:47 pm    Post subject: Thermostatic switch/relay Reply with quote
Guys
I installed a couple of cooling fans in my RV-10 dashboard, actually copying other builders idea, to extract heated air from the back of the avionics, which is blown in the inside face of the windshield, thus also serving as a windshield defrost system.
I am planning to use a 3 position switch, off, on, and automatic, in which this last position is to be connected to a thermostatic switch/relay that will turn on the coolers only when the temperature behind the avionics reaches a preset or an adjustable temperature.
Will somebody please point me to such a thermostatic switch/relay, and a source for it.
Carlos
PostPosted: Sat Oct 08, 2016 5:28 pm    Post subject: Re: Thermostatic switch/relay Reply with quote
https://www.amazon.com/RioRand-Thermostat-Temperature-Controller-Waterproof/dp/B00KCCX0EE
https://www.amazon.com/12V-Digital-Temperature-Controller-Thermostat/dp/B00C4TEEF2
Make your own electronic temperature controller:
http://ww1.microchip.com/downloads/en/DeviceDoc/21448D.pdf
It will not hurt anything to leave the fans running continuously.
Joe Gores
ceengland7(at)gmail.com
PostPosted: Sat Oct 08, 2016 8:31 pm    Post subject: Thermostatic switch/relay Reply with quote
On 10/8/2016 6:26 PM, Carlos Trigo wrote:
Guys
Carlos
I googled '12 volt thermostat'.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=12%20volt%20thermostat
The 1st one I checked says it will do both heating & cooling:
Web site for it:
http://www.thermomart.com/index.php?route=product/product&product_id=149
Does that help, as a starting point?
Charlie
whodja
PostPosted: Sun Oct 09, 2016 4:41 am    Post subject: Re: Thermostatic switch/relay Reply with quote
Another option from McMaster;http://www.mcmaster.com/#thermostats/=14irk9r
Mauledriver(at)nc.rr.com
PostPosted: Mon Oct 10, 2016 9:17 am    Post subject: Thermostatic switch/relay Reply with quote
That's what I did - just have it on all the time. Simplicity
Joe Gores
http://forums.matronics.com/viewtopic.php?p=461109#461109
PostPosted: Mon Oct 10, 2016 9:33 am    Post subject: Thermostatic switch/relay Reply with quote
Well, it can be, but I am too sensitive to noise ...
Carlos
-----Mensagem original-----
De: owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Bill Watson
Enviada: Monday, October 10, 2016 6:15 PM
Para: aeroelectric-list(at)matronics.com
Assunto: Re: Re: Thermostatic switch/relay
--> <Mauledriver(at)nc.rr.com>
--> <fransew(at)gmail.com>
Joe Gores
PostPosted: Mon Oct 10, 2016 9:51 am    Post subject: Thermostatic switch/relay Reply with quote
Say what? Is there supposed to be a winking emotie after that statement?
If not, you might need to consider another hobby. Smile
Seriously, the big fan will hide the noise of any number of cooling fans
you might install in/behind the panel.
Charlie
Carlos
> Joe Gores
PostPosted: Mon Oct 10, 2016 10:10 am    Post subject: Thermostatic switch/relay Reply with quote
Hello Charlie
Yes, a friend of mine who happens to be a doctor (ear nose & throat) tells
me that I probably have a higher sensibility to some frequencies ...
And I don't like that noise when the big fan is not swinging.
Carlos
[mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Charlie
England
Enviada: Monday, October 10, 2016 6:50 PM
--> <ceengland7(at)gmail.com>
Seriously, the big fan will hide the noise of any number of cooling fans you
Charlie
--> <trigo(at)mail.telepac.pt>
Carlos
Watson
> Joe Gores
art(at)zemon.name
PostPosted: Mon Oct 10, 2016 10:18 am    Post subject: Thermostatic switch/relay Reply with quote
Wait... you're flying an AIRPLANE and you're worried about the noise in the cockpit from a fan???? Have you considered a glider?
    -- Art Z. (only half kidding)
On Mon, Oct 10, 2016 at 12:31 PM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
--> AeroElectric-List message posted by: "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
PostPosted: Mon Oct 10, 2016 10:44 am    Post subject: Thermostatic switch/relay Reply with quote
Yes Art
I also fly gliders, and must confess that glider flying is indeed the supreme flying experience!
No kidding
Carlos
P.S. – I must add that I’m still puzzled why we don’t care to reduce noise inside airplanes like the car builders have already done it
De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Em nome de Art Zemon
Enviada: 10 de outubro de 2016 19:17
PostPosted: Mon Oct 10, 2016 11:13 am    Post subject: Thermostatic switch/relay Reply with quote
I don't think that we don't care; it's just much more difficult to achieve in an a/c.
For perspective, several years ago one of the European auto mfgrs was looking at using active noise cancelling in the cabin of their cars. Their initial efforts at a (very complex, multi sensor, multi transducer) system seemed to work ok, and by their numbers, they would have been able to remove close to 100 lbs of sound reduction material from the car by using the system. This was on a car that sells for far north of $50K, and development costs would be spread over hundreds of thousands of units.
Now, if I try the passive noise reduction approach in my 1000 lb plane, I've added 10% to the empty weight, and I haven't yet added the additional 60-80 lbs of muffler/exhaust system that the car carries. Just not practical, unless you can afford a jet, and the weight it can carry. Even then, you're not likely to come close to a premium car in noise level.
On Mon, Oct 10, 2016 at 1:41 PM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Yes Art
No kidding
Carlos
De: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] Em nome de Art Zemon
Para: aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)
PostPosted: Mon Oct 10, 2016 12:18 pm    Post subject: Thermostatic switch/relay Reply with quote
I agree on the supreme experience but there's nothing quiet about it.  Whether slogging around in a drafty 2-33 or zooming about in a modern 18m racer with the speed-to-fly audio constantly sounding off, it's noisy Wink
Bill "who still gets airsick from the sound of a vario" Watson
On 10/10/2016 2:41 PM, Carlos Trigo wrote:
<![endif]--> <![endif]-->
Yes Art
No kidding
Carlos
www.avast.com
PostPosted: Mon Oct 10, 2016 3:24 pm    Post subject: Re: Thermostatic switch/relay Reply with quote
Instead of buying a speed controller or thermostat, buy a fan that comes with a speed selector switch. Let the buyer beware when it comes to manufacturer's claims of quiet. Larger diameter and slower speed usually results in less noise. A 120 mm fan will be quieter than an 80 mm fan. Compare the RPM and Db ratings. Computer fans are designed to operate at 12 volts. They might run faster and make more noise at 14 volts. The voltage can be dropped with a resistor or diodes. The Antec TrueQuiet 120mm LED fan has two speeds and silicone mounting grommets.
Joe Gores
ashleysc(at)broadstripe.n
PostPosted: Mon Oct 10, 2016 5:47 pm    Post subject: Thermostatic switch/relay Reply with quote
Hi Carlos;
One word: weight.
Cheers! Stu.
Sent: Monday, October 10, 2016 11:41:50 AM
Subject: RE: Re: Thermostatic switch/relay
Yes Art
No kidding
Carlos
