philperry9
Posted: Wed Sep 28, 2016 6:00 pm Post subject: Lord Adhesive |
For those of you who put down Lord 7545A&E for the windows, I've got a question.
After leaving my windscreen out as long as humanly possible, it's time to put it in and I'd like to use Lord if possible. I see they make an applicator gun for it, but can it be applied with a simple caulk gun?
Curious to know. I just can't see spending another $60 for a one-time use applicator gun. I'd probably go ahead and just use Weld-on and make the wind screen like all my others.
Phil
civengpe
Posted: Wed Sep 28, 2016 6:10 pm Post subject: Lord Adhesive |
I've got the gun if you want to borrow it.
Shannon
On Wednesday, September 28, 2016, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
| Quote: | For those of you who put down Lord 7545A&E for the windows, I've got a question.
Phil
Posted: Wed Sep 28, 2016 6:37 pm Post subject: Lord Adhesive |
Where are you located? You can mix it separately from the mixer nozzle, but you can't use a normal caulk gun. You would have to push the plunger on both bottles the exact same amount then mix it in a cup if you don't have the right gun.
Jesse SaintSaint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Sep 28, 2016, at 10:06 PM, Shannon Hicks <civeng123(at)gmail.com (civeng123(at)gmail.com)> wrote:
| Quote: | I've got the gun if you want to borrow it.
Shannon
Phil
