Fuel leak
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
jetblast1(at)me.com
PostPosted: Mon Sep 26, 2016 5:47 am    Post subject: Fuel leak Reply with quote
Regarding fuel leak,
That rectangular unit is the fuel scavenger system which drains excess fuel from various areas of the engine. It is normal to have some fuel leak out of there. How much fuel are you losing? Is it coming out of the small tube that is at the bottom of the box?
John F. Cabrera
> On Sep 24, 2016, at 12:03 AM, L29-List Digest Server <l29-list(at)matronics.com> wrote:
> Online Versions of Today's List Digest Archive
> Today's complete L29-List Digest can also be found in either of the
> two Web Links listed below. The .html file includes the Digest formatted
> in HTML for viewing with a web browser and features Hyperlinked Indexes
> and Message Navigation. The .txt file includes the plain ASCII version
> of the L29-List Digest and can be viewed with a generic text editor
> such as Notepad or with a web browser.
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-09-23&Archive=L29
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-09-23&Archive=L29
> EMail Version of Today's List Digest Archive
> L29-List Digest Archive
> Total Messages Posted Fri 09/23/16: 1
> Today's Message Index:
> 1. 07:20 AM - issues? (skidmk)
> ________________________________ Message 1 _____________________________________
> Time: 07:20:44 AM PST US
> Subject: issues?
> From: "skidmk" <skidmk(at)gmail.com>
> Gents,
> I filled the cooling unit oil reservoir several times over the past few days. Approximately
> 250 ml was used in total. In all cases the reservoir slowly emptied,
> and a steady dripping leak saw observed coming from an unidentifiable unit
> below the Cooling Turbine (as labeled and observed via borescope.)
> I can confirm that there is no leak in the reservoir or the hose running down to
> the Turbine unit. The leak is internal to the Cooling Turbine and/or the assembly
> attached below it.
> Image
> Oil is coming from unit with 3 holes in center of photo. Appears to be from left
> hand holes only. (Looking up)
> FUEL LEAK
> A fuel leak has developed out of the overflow pipe located just aft of the large
> belly panel I had removed to investigate the oil leak. The fuel appears to
> be coming from a rectangular unit just below the burner cans.
> Rectangular unit that fuel is draining from. (Looking aft)
> Any further thoughts?
> Mike &quot;Skidmk&quot; Bourget
> Ottawa, Ontario
> http://forums.matronics.com/viewtopic.php?p=460685#460685
> http://forums.matronics.com//files/fuel_drain_130.jpg
> http://forums.matronics.com//files/turbine_232.jpg
> http://forums.matronics.com//files/borescope_192.jpg
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
skidmk
PostPosted: Wed Sep 28, 2016 7:25 am    Post subject: Re: Fuel leak Reply with quote
not a ton. It did stop eventually. Our second ship leaked out about 4 gallons over the spring months (march to June). Once she was out fying she stopped leaking. Took her to her hangar for a month (I have to travel for work) and she started leaking again.
i think she's mad at me....
Mike "Skidmk" Bourget
Ottawa, Ontario
skyking76t(at)verizon.net
PostPosted: Wed Sep 28, 2016 4:50 pm    Post subject: Fuel leak Reply with quote
If the internal fuel tank is half full to full, fuel will leak out the fuel scavenge tube. If under half full, there shouldn't be any fuel venting or very minimal. Fuel venting is normal as fuel will migrate from the internal tank to the fuel scavenge tube over a period of time. The amount depends on the amount of fuel in the internal tank, ambient temp, and how the aircraft is sitting. This is what I have found on my L-29. Hope it helps
Anthony Royal
L-29 Maj Kissoff
On Wednesday, September 28, 2016 11:29 AM, skidmk <skidmk(at)gmail.com> wrote:
--> L29-List message posted by: "skidmk" <skidmk(at)gmail.com (skidmk(at)gmail.com)>
Ottawa, Ontario
http://forums.matronics."http://www.matronics.com/Navigator?L29-List" target="_blank">http://www.= &n--> =
skidmk
PostPosted: Sun Oct 02, 2016 5:49 am    Post subject: Re: Fuel leak Reply with quote
That helps alot, this winter one of our birds was sitting with about 580 gals on board, and she leaked pretty much non stop. Took her out for this summer and most of our ops left her with 200gals or less. Not a drop.
Our second bird stops leaking at 600gals
thanks again.
Ottawa, Ontario
migfighter42(at)gmail.com
PostPosted: Sun Oct 02, 2016 6:12 am    Post subject: Fuel leak Reply with quote
Thats our experience as well, anything over 400L drives a small leak. Under 400L, nothing.
Bill Culberson
Red Star Aero Services
N39DE
Sent from my T-Mobile 4G LTE Device
-------- Original message --------
Date: 10/2/16 8:49 AM (GMT-06:00)
To: l29-list(at)matronics.com
Subject: L29-List: Re: Fuel leak
--> L29-List message posted by: "skidmk" <skidmk(at)gmail.com>
thanks again.
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=460888#460888
_-============================================================
_-=          - The L29-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?L29-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=              - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-=   --> http://wiki.matronics.com
_-=             - List Contribution Web Site -
_-=  Thank you for your generous support!
_-=                              -Matt Dralle, List Admin.
_-=   --> http://www.matronics.com/contribution
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
