		haribole
  Joined: 21 Feb 2014 Posts: 33 Location: United States
				 Posted: Fri Sep 16, 2016 4:38 pm    Post subject: VOR/LOC/GS BALUN Fabrication |
				Meant to include the link:
 http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html
 On Fri, Sep 16, 2016 at 8:35 PM, Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)> wrote:
  	  | Quote: | 	 		  Hello Group
 I was trying to fabricate this cable, but having trouble in step 2. The exposed braid refuses to suck up the molten solder. The moment I put a soldering iron ( a standard radio shack 35W iron) the solder freezes up and won't melt and flow. Have enough flux applied to the braid, not sure what I can do to get this tinned.
 any pointers would be highly appreciated
 Hari
		haribole
				Hello Group
 Hari
		user9253
  Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
				 Posted: Fri Sep 16, 2016 6:16 pm    Post subject: Re: VOR/LOC/GS BALUN Fabrication |
				What kind of solder are you using?  Some types melt at a higher temperature.  The wire might not be getting hot enough or made of a metal that does not readily accept solder.  What kind of flux are you using?  Solder made for electrical connections usually has a flux core and extra flux is not needed.  Flux made for plumbing is acid based and will cause electrical connections to corrode and fail eventually.
  _________________ Joe Gores |
		ceengland7(at)gmail.com Guest
				 Posted: Sat Sep 17, 2016 5:45 am    Post subject: VOR/LOC/GS BALUN Fabrication |
				Can you attach a pic of your actual setup (coax, iron, solder, etc)?
 Misc thoughts: Iron tip must be clean & tinned with solder, for efficient heat transfer to the work. Also, some 35W irons have very low mass tips, and can't keep up with the heat transfer into a large 'sink' like braid. 60/40 or 63/37 rosin core electronics solder; Electronics grade flux; and last, this is a long shot, but make sure your coax is copper braid shield and not a foil shield. There are some coaxes that have an aluminum foil shield instead of braided copper.
 On Fri, Sep 16, 2016 at 7:35 PM, Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)> wrote:
  	  | Quote: | 	 		  Meant to include the link:
 Hari
		haribole
				 Posted: Sat Sep 17, 2016 9:39 am    Post subject: VOR/LOC/GS BALUN Fabrication |
				I was putting in the cable for a new build and after reading the description again, postponed this till I actually test the performance.Thanks to all for the pointers.
 On Sat, Sep 17, 2016 at 9:43 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
  	  | Quote: | 	 		  Can you attach a pic of your actual setup (coax, iron, solder, etc)?
 Hari
