digidocs
Posted: Mon Sep 12, 2016 8:14 am Post subject: Headset jacks |
Hi list,
I've been thinking of locating my front headset jacks on the outside edges of the panel switch bar and the rear jacks at the forward edge of the outboard "armrest" panels.
How did the jacks you installed work out? Are there any changes you wish that you made prior to drilling?
Thanks for the help,
David
Posted: Mon Sep 12, 2016 8:39 am Post subject: Headset jacks |
Originally I had the jacks mounted on the switch panel. My other planes
have the jacks close to the same place. On the other planes I have to
drape the cords so they're out of the way for entry and egress. PITA
for me. So, I placed the jacks on the tunnel cover for both front and
rear about where the hips would sit so they'd be out of the way . I
wired the switch panel jacks direct to radios for emergency use in case
the intercom went belly up.. Headsets will hang from my overhead
console so they would be out of the way for entrance and egress. I'm not
flying yet so I don't know if my thought process is good or not.
Linn
On 9/12/2016 11:57 AM, David Carr wrote:
| Quote: | Hi list,
David
Posted: Mon Sep 12, 2016 8:44 am Post subject: Headset jacks |
I used two of these for the front: http://www.aircraftspruce.com/catalog/avpages/forbes5.php?clickkey=3041841
One is located on each side of the tunnel, just forward of the seat. I like the jacks here as the headset cord is not going over your lap or legs. In the back I mounted the jacks on the flap cover, just outboard of the tunnel on each side. Same idea – the cords do not cross over your lap or legs.
I’m happy on how they worked out.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Carr
Sent: Monday, September 12, 2016 11:58 AM
Subject: Headset jacks
Hi list,
David
Albert Gardner
Posted: Mon Sep 12, 2016 9:00 am Post subject: Headset jacks |
That's the way I did it. I was thinking of getting the rear plugs in a position so that it would be difficult to break them. Abby's interior package had some room from plugs on the armrests, maybe lots others did the same. I don't ride back there much but none have been broken. Up front extra cords can be tucked into side pockets.
Albert Gardner
RV-10 N991RV
Yuma, AZ
Sent: Monday, September 12, 2016 8:58 AM
Hi list,
David
RV-10 N991RV |
Posted: Mon Sep 12, 2016 9:13 am Post subject: Headset jacks |
That's exactly what I recommend.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
| Quote: | On Sep 12, 2016, at 12:34 PM, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
Originally I had the jacks mounted on the switch panel. My other planes have the jacks close to the same place. On the other planes I have to drape the cords so they're out of the way for entry and egress. PITA for me. So, I placed the jacks on the tunnel cover for both front and rear about where the hips would sit so they'd be out of the way . I wired the switch panel jacks direct to radios for emergency use in case the intercom went belly up.. Headsets will hang from my overhead console so they would be out of the way for entrance and egress. I'm not flying yet so I don't know if my thought process is good or not.
Linn
> Hi list,
> David
Dave Saylor
Posted: Mon Sep 12, 2016 12:02 pm Post subject: Headset jacks |
David,
My jacks are pretty much as you're describing. The fears work out fine but I wish my front jacks were more towards the center. The cords can be a hassle getting in and out.
No matter where you but them, be sure they're easy to see in flight without having to crane around too much.
--Dave
On Monday, September 12, 2016, David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
| Quote: | Hi list,
David
_________________ --Dave
KWVI |
Posted: Tue Sep 13, 2016 9:02 am Post subject: Headset jacks |
Here's what I did in the front seats to accommodate powered Bose jacks and regular jacks. It has worked great.
Front Jacks mounted on side walls
What's not shown are the hooks mounted out of sight on the side walls near the rudder pedals. When not in use, the headsets are hung there, out of the sun and mostly out of sight. It keeps the cables out of the way for entry and exit though they do lay on the floor. Even new passengers have no trouble returning the headset to the hook even though the hook itself can't be seen.
