docclv(at)windstream.net Guest
Posted: Tue Aug 30, 2016 6:33 pm Post subject: Gear wheel nuts |
The landing gear wheel nuts should be only hand tight (just to the point
where there is no play in the wheel when it is pushed in and out) then
backed off to the nearest cotter pin alignment hole. At most you should
use a pair of pliers to snug the nut up. You will not need a "wrench"
to tighten the nuts ever. Getting the cotter pin through the nut and
axle can be a challenge though. Good luck. Doc
41087
123CV
