kearney
Posted: Thu Aug 18, 2016 1:52 pm Post subject: Prop Governor Alternative |
Hi
I was a bit concerned that my PCU5000X governor might have an exposure to the MT issue. I was *told* that they shared common parts. To make a long story short I sport to APS who distributes these units. Here is the note I received from them (I told Sean I would post it here).
So for those facing the MT issue, there is another choice....
Cheers
Les
Les,
Briefly going over what we discussed earlier, the Aero Technologies, LLC PCU5000X is manufactured by Jihostroj in the Czech Republic, we started our partnership back in 2004 and it continues to today. MT Propellers governor is manufactured by AVIA also in the Czech Republic but it is a competing company with its own proprietary design. “VAF Special” is the code to use if you want a PCU5000X at $1,250.00 USD plus shipping, normal MSRP is $1,600.00 USD. Thank you for the phone call and being a loyal aviator.
Sean O'Keefe
Business Unit Manager
Aircraft Propeller Service, LLC D.B.A.
595 Telser Road
Lake Zurich, IL 60047
1(847) 541-1133 ext. 109
Direct Line 1(224) 676-6909
tsts4
Posted: Fri Aug 26, 2016 1:02 pm Post subject: Re: Prop Governor Alternative |
Another option is the Hartzell gov.
Model S-1-26 for Narrow Deck 540s
Model S-1-32 for Wide Deck 540s
And if you use Van's throttle quadrant you need the extension, Hartzell part number 103568 governor arm extension
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
Greg McFarlane
Joined: 12 Apr 2012 Posts: 58 Location: Albany Western Australia
Posted: Sat Aug 27, 2016 2:43 am Post subject: Re: Prop Governor Alternative |
The other alternative is the MT P-860-5 with the gear reduction of .947:1 that MT recommend for the Wide Deck IO 540s that most of the RV10 fleet have. The MT P-860-3 as others, including MT have said has a gear reduction of .895:1 which is recommended for the older narrow deck engines.
40555
Posted: Sat Aug 27, 2016 5:26 am Post subject: Prop Governor Alternative |
Thanks,I will return to MT for the service bulletin...
Craig
On Sat, Aug 27, 2016 at 3:43 AM, Greg McFarlane <grbcmcfarlane(at)gmail.com (grbcmcfarlane(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: "Greg McFarlane" <grbcmcfarlane(at)gmail.com (grbcmcfarlane(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=459947#459947
WIKI -
Thank You,
Craig RufiEmail craigr60(at)gmail.com (craigr60(at)gmail.com)
Cell 805 402-6480
woxofswa
Posted: Sat Aug 27, 2016 11:09 am Post subject: Re: Prop Governor Alternative |
| Greg McFarlane wrote: | | The other alternative is the MT P-860-5 with the gear reduction of .947:1 that MT recommend for the Wide Deck IO 540s that most of the RV10 fleet have. The MT P-860-3 as others, including MT have said has a gear reduction of .895:1 which is recommended for the older narrow deck engines. |
That's true. However, in the past week it has been confirmed that:
1. The internals of the -3 and -5 are exactly the same.
2. The ratio difference should not cause a failure.
3. The -5's will be included in the SB.
4. MT and Van's originally recommended the -3 for all 540 engines.
5. Van's sold dozens if not hundreds of -3 units to wide deck owners. I don't believe that Van's catalog even offered a -5 until the outbreak began.
6. Van's offered two Hartzell models with the two ratios, but until recently listed them in the catalog as for "O" or "IO" which doesn't make any difference.
7. Jihostroj used to make the PG's for MT until AVIA took over and they all trace back to an original Czech military design. (so I've been told)
Of course all is subject to change on almost a daily basis.
I still believe that it is too early to make a definitive decision on anything other than the correct Hartzell for your configuration if you need to fly right away.
My opinion only YMMV.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
kearney
Posted: Sat Aug 27, 2016 1:12 pm Post subject: Re: Prop Governor Alternative |
Myron
I don't agree with your final conclusion.
Based on my discussion with APS (who market the PCU5000X), Avia took over the MT PG in 2004. The MT design (from Avia) is different than the PCU5000X and has evolved independently.
Since 2004, the Jihostroj has been selling PGs (e.g. the PCU5000X) based on its proprietary design.
Personally, I have no problem flying behind my PCU5000X.
For info, I repeat Sean's email:
Les,
Sean O'Keefe
595 Telser Road
woxofswa
Posted: Sat Aug 27, 2016 2:30 pm Post subject: Re: Prop Governor Alternative |
That's fine. I completely understand. The value of these forums is information and debate.
When something like this happens to you, the first thing that happens is you have to make dozens of phone calls. The first time I called MT they said they'd never heard of this issue. The second time I called them, I was told that they (MT-USA) were just a satellite office and that all inquiries would have to be directed to Germany which normal business hours end at 8:00 am my time. When I finally got ahold of Germany, I was told that they were waiting for info back from the CR and that all future info would be handled by the USA office, the VERY OFFICE THAT TOLD ME TO CALL EUROPE.
When I called Hartzell, I was immediately connected to a tech rep that spoke my language and spent 45 minutes with me answering questions and later voluntarily spoke with my insurance adjuster to clarify an extremely important issue which saved me a lot of money.
I have zero basis to degrade the PCU model. It may be the best there is. I have just garnered a new appreciation for US based companies.
We are all creations of the sum of our collective experience. I write this sitting in a VW Passat TDI that VW is about to buy back.
Mesa, AZ
Flew May 10 2014 |
trigo(at)mail.telepac.pt Guest
Posted: Sat Aug 27, 2016 2:43 pm Post subject: Prop Governor Alternative |
Dear Myron
That's called nationalism ...
Not good, not bad, it's just what it is
Carlos
(No hard feelings from Europe)
Enviado do meu iPhone
No dia 27/08/2016, às 23:30, woxofswa <woxof(at)aol.com> escreveu:
Myron Nelson
Mesa, AZ
Flew May 10 2014
http://forums.matronics.com/viewtopic.php?p=459961#459961
woxofswa
Posted: Sat Aug 27, 2016 3:23 pm Post subject: Re: Prop Governor Alternative |
Carlos,
My parents were European. My wife's family Canadian. I spent a good part of my childhood in England and my early Adulthood in Argentina. I possess a European CAA license obtained in Belgium. I just bought my wife a Subaru to replace her beloved VW TDI.
I assure you that my "asunto" is one of access and convenience, and not nationalism.
Mesa, AZ
Flew May 10 2014 |
Posted: Sun Aug 28, 2016 12:49 am Post subject: Prop Governor Alternative |
I understand!
We are both citizens of the world...
Hope you solve your prop gov problem
Cheers
Carlos
No dia 28/08/2016, às 00:23, woxofswa <woxof(at)aol.com> escreveu:
Carlos,
Myron Nelson
Mesa, AZ
Flew May 10 2014
http://forums.matronics.com/viewtopic.php?p=459964#459964
kearney
Posted: Sun Aug 28, 2016 8:24 am Post subject: Re: Prop Governor Alternative |
Myron
Your post mentioned that Hartzell clarified an important issue that saved you a lot of $$$.
Can you share the specifics? As I understand it the issue is with the MT PG. If this has a failure that causes other issues (i.e. damage to the engine), is it an insurable event. I would have thought that the liability would have been with MT.
Anyway, I am curious..
Cheers
Les
tsts4
Posted: Sun Aug 28, 2016 8:32 am Post subject: Re: Prop Governor Alternative |
| kearney wrote: | Myron
Cheers
Les |
Not Myron but the issue he mentioned involved replacing his prop as a result of the PG failure. His adjuster balked initially but we have the same underwriter and when his found out than my adjuster had approved the replacement based upon Hartzell's tech data and direct recommendation the replacement was approved.
kearney
Posted: Sun Aug 28, 2016 9:02 am Post subject: Prop Governor Alternative |
Hi Todd
I think I understand what happened. I am just curious as to why damage arising from a part failure is an insurance event. I am glad it worked out hit you and Myron, I am just trying to understand the insurance logic - if there is such a thing.
Cheers
Les
| Quote: | On Aug 28, 2016, at 10:32 AM, tsts4 <tsts4us(at)gmail.com> wrote:
kearney wrote:
> Myron
> Cheers
> Les
Todd Stovall
aka Auburntsts on EAA, AOPA, and VAF
RV-10 N728TT -- Grounded for engine teardown!!!!
http://forums.matronics.com/viewtopic.php?p=459984#459984
tsts4
Posted: Sun Aug 28, 2016 9:59 am Post subject: Re: Prop Governor Alternative |
| kearney wrote: | Hi Todd
Cheers
Les
| Quote: | On Aug 28, 2016, at 10:32 AM, tsts4 <tsts4us> wrote:
kearney wrote:
> Myron
> Cheers
> Les
Todd Stovall
Simple. Both of our policies covered the damage caused by a parts failure (we have different agency's but have the same underwriter). So replacement of the damaged PG is not covered but the subsequent damaged caused by the failure is. In my case, what is covered is the shipping, teardown, inspection, and repair of the engine, inspection and repair, if necessary, of the mags, replacement of the prop, and replacement of the alternators. All of this is based upon manufactured guidance and tech data due to the overspeed. That estimate is almost $23K and that's before they find any issues with the engine which I'm sure there will be at least one repair--the prop gov drive assembly. Without insurance I wouldn't be able to afford the repairs and replacements.
woxofswa
Posted: Sun Aug 28, 2016 10:00 am Post subject: Re: Prop Governor Alternative |
The issue is actually whether the prop governor and prop are one single component of two different parts or two separate components. Insurance policy verbiage is a little vague in that respect. Insurance doesn't cover a failed component. However, the good ones cover anxillary damage to other components as a result of a failed component.
I don't want to get into too much detail yet, but suffice to say that I will always stick with Gallagher and AIG as long as they'll have me.
Mesa, AZ
Flew May 10 2014 |
kboatright1(at)comcast.ne Guest
Posted: Sun Aug 28, 2016 10:01 am Post subject: Prop Governor Alternative |
The convention seems to be that the first thing that fails is your responsibility. Everything after that is often handled by insurance.
Think: Engine failure followed by an off airport landing.
Or gear failure followed by a belly landing.
Governor failure followed by an engine tear down or prop replacement due to an overspeed seems to be treated similarly.
| Quote: | On Aug 28, 2016, at 12:55 PM, Les Kearney <kearney(at)shaw.ca> wrote:
Hi Todd
Cheers
Les
> kearney wrote:
>> Myron
>> Cheers
>> Les
> Todd Stovall
jdriggs49(at)MSN.COM Guest
Posted: Sun Aug 28, 2016 10:39 am Post subject: Prop Governor Alternative |
That's good! Who is your insurance company if you don't mind me asking?!
| Quote: | On Aug 28, 2016, at 1:22 PM, tsts4 <tsts4us(at)gmail.com> wrote:
kearney wrote:
> Hi Todd
> Cheers
> Les
> Sent from my iPhone
>> On Aug 28, 2016, at 10:32 AM, tsts4 wrote:
>> kearney wrote:
>>> Myron
>>> Cheers
>>> Les
>> Todd Stovall
Todd Stovall
http://forums.matronics.com/viewtopic.php?p=459988#459988
tsts4
Posted: Sun Aug 28, 2016 11:21 am Post subject: Re: Prop Governor Alternative |
| jdriggs49(at)MSN.COM wrote: | That's good! Who is your insurance company if you don't mind me asking?!
| Quote: | On Aug 28, 2016, at 1:22 PM, tsts4 <tsts4us> wrote:
Falcon (partnered with USAA)
larkrv10(at)gmail.com Guest
Posted: Sun Aug 28, 2016 5:55 pm Post subject: Prop Governor Alternative |
Guys, my conversation with my broker here in Ontario indicates there is no insurance coverage for me unless I had damage due to for example a hard landing after my governor failure. While this whole governor fiasco is disturbing and ultimately costly for everyone, consider yourselves lucky to have that type of coverage. AIG Canada isn't biting.......
Rick
Southampton, Ont
#40956
On Sun, Aug 28, 2016 at 3:21 PM, tsts4 <tsts4us(at)gmail.com (tsts4us(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: "tsts4" <tsts4us(at)gmail.com (tsts4us(at)gmail.com)>
> Sent from my iPhone
Todd Stovall
http://forums.matronics.com/viewtopic.php?p=459996#459996
-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?RV10-List
_blank" rel="noreferrer">http://forums.matronics.com
WIKI -
lank" rel="noreferrer">http://wiki.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
woxofswa
Posted: Sun Aug 28, 2016 6:58 pm Post subject: Re: Prop Governor Alternative |
Don't give up Rick. Keep meticulous records. Hopefully MT steps up for everyone.
Mesa, AZ
Flew May 10 2014 |
