brubakermal(at)yahoo.com Guest
Posted: Tue Aug 16, 2016 7:21 am Post subject: Voltage regulator |
I am packing a kolb today to travel to minis Ota can anyone please call me about what to lookout for on the mk3 extra 989 513.3022
Sent from Yahoo Mail on Android
| Quote: | On Sun, Jul 24, 2016 at 21:53, Malcolm Brubaker
<brubakermal(at)yahoo.com> wrote:
Cool herb you hit the ground running were in Indiana tonight
| Quote: | On Sun, Jul 24, 2016 at 1:50 PM, Herb
<Herbgh(at)nctc.com> wrote:
My S-14 arrived today...with the HKS-700E engine
Looking at the engine schematic...the 5 wire voltage reg does not have a wire that goes to the CDI boxes..! 3 wires are white and see the three Phase ac voltage... the Cdi boxes have two wires coming from the accessory case and are likely magnetic pickups... 180 degs apart for the two cylinders or could be two pickups for each cyl.. one full adv and one starting and low rpm? ... If single coil they must be set to max advance and the CDI box adds the delay for starting and low rpm operation...? To me...this means that a lot of motorcycle cdi's should work...? Most scooters work similarly... 10 dollar cdi box beats whatever HKS wants... ..whether I would use a Chinese one??? Not likely... I have had two bail on my scooter.. Betting Yamaha has a reasonable replacement?
Herb On 07/23/2016 01:10 AM, Larry Cottrell wrote:
| Quote: | I checked and the proposed delivery date was aug to sept. I cancelled that and ordered the $48.00 one. It will get here sooner. :-/
Larry
| Quote: | --
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny."
Aristotle |
