Ernie
Posted: Sun Aug 07, 2016 9:45 am Post subject: Cylinder Questions |
Does anyone know of a piston pin removal tool for the Housai engine. One of the end bushings is stuck in place, and I can't seem to get the pin to come out the other side. I was hoping that someone has come up with a press.
Ernie
Ernie
Posted: Sun Aug 07, 2016 11:32 am Post subject: Cylinder Questions |
Never mind.....2 sockets and a threaded rod.
On Sun, Aug 7, 2016 at 1:44 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
| Quote: | Does anyone know of a piston pin removal tool for the Housai engine. One of the end bushings is stuck in place, and I can't seem to get the pin to come out the other side. I was hoping that someone has come up with a press.
Ernie
Lancer
Joined: 21 Apr 2016 Posts: 30 Location: Cairns, Australia
Posted: Tue Aug 09, 2016 12:56 am Post subject: Re: Cylinder Questions |
Ernie,
The wrist pin needs to be pressed from the rear of the engine and removed at the front. I use a 3/8 socket extension...Put the large end in through the rear retainer and it will locate in the wrist pin to facilitate removal. The front retainer is floating and will slide out when you start tapping the extension/drift. The rear retainer is pressed in place and is not intended to be removed.
Pistons and cylinders are numbered at the factory assisting in replacing them in the correct location.
Be careful to keep the pushrods secure in the pushrod tube specially with the lower cylinders as the cam followers are made up of a few small parts which don't fare too well if not seated correctly when the cylinder is refitted
Good Luck
Lance
_________________ You can run but you can't hide |
